What LPG System works with NON-SEQUENTIAL 6 cyl?
It has been suggested that my BRC system could be incompatible with my old car with an old motronic non-sequential electronic injection system.
My car has all six injectors supplied by one signal wire (Full bank pulsing. Two identical pulses per revolution).
The BRC system only gives the option for semi-sequential or fully sequential.
What system will work with my car?
And will it work with BRC injectors or do I have to replace those too?
- Installer
Re: What LPG System works with NON-SEQUENTIAL 6 cyl?
I fit AEB with full group injection cars normaly. I've converted a lot of Volvo's and BMW's that run motronic injection without any problems at all.
The BRC system should work, I have you spoken to BRCGB to discuss the problem?
No I haven't. I plan to call them tomorrow. I have a feeling they will not be too interested in helping unless I want to use one of their own approved installers and this is a DIY job. But it is worth giving them a call as I have nothing to lose.classicswede wrote:I fit AEB with full group injection cars normaly. I've converted a lot of Volvo's and BMW's that run motronic injection without any problems at all.
Do AEB ECUs plug into the same loom or do I have to get a whole new system?
- Installer
You will need a full system and have to re wire it in.
Oh crikey! I don't want to do that unless I have to. I might try and find a different way around it then. I don't want to go through all that again.classicswede wrote:You will need a full system and have to re wire it in.
The AEB ECU may or may not work very well with BRC injectors too, and certainly won't like BRC dash switch or sensors etc. If yer gonna swap you probably want the whole shebang.
I have to say say I don't think I've ever done a 6-cyl (or 8-cyl) car that was a true single bank with any kind of LPG injection system, wouldn't like to guess which ones will work for sure. Even old Jetronics were banked after a fashion.
e301988325i
Does it actually not work? Does the LPG ECU actaully care if all the injectors are fired at once, I understand they just copy what the petrol ECU is doing with a modifier value.sportston wrote:It has been suggested that my BRC system could be incompatible with my old car with an old motronic non-sequential electronic injection system.
You would have to make all six electronic connections to all six petrol injectors but you'd have to do this anyway?
I'm no expert just thinking out loud, but my 6cyl bmw E30 is dual bank motronic, and single bank with the ignition pulse sensor removed.
- Installer
If you read his other thread 2 cyls are reading way offe301988325i wrote:Does it actually not work? Does the LPG ECU actaully care if all the injectors are fired at once, I understand they just copy what the petrol ECU is doing with a modifier value.sportston wrote:It has been suggested that my BRC system could be incompatible with my old car with an old motronic non-sequential electronic injection system.
- Installer
There is no option for BRC injectors in any version of AEB software that I have seen. There are some options for 2ohm injectors with AEB but no idea if the peak and hold would be correct.rossko wrote:The AEB ECU may or may not work very well with BRC injectors too, and certainly won't like BRC dash switch or sensors etc. If yer gonna swap you probably want the whole shebang.
Almost all 4 cylinders system fire all 4 injectors at the same time.
D jet on 6/8 cyl can fire in either goups of 2 or 3 or 4 but run a switched live
Motronic normaly switches all cylinders at the same time
The various L jet systems tend to switch in groups of 2 or 3
AEB never has a problem with any of the systems (other than D jet where it will not work with the switched live) but firing all cylinders at the same time does not cause a problem. On fuel group 8 cylinder engines it is not a good idea to use low resistance injectors as they can cause higher ECU tempratures.
Hi you can check LPGTECH http://www.lpgshop.co.uk/lpg-lpgtech-6c ... -kit-mini/
it has all necessary features you need to calibrate your car , working on sequential , semi-sequential, full group
you can adjust each injector or banks for flow correction or correction of opening times.
Its in reasonable price, has 2 years manufacturer warranty,UKLPG approved and we will provide you with technical support.
WWW.LPGSHOP.CO.UK
I was looking at that ECU earlier this evening.LPGTECH wrote:Hi you can check LPGTECH http://www.lpgshop.co.uk/lpg-lpgtech-6c ... -kit-mini/
Will it work with brc injectors and a brc reducer?
I like that I have a fairly good quality reducer and injectors and wouldn't mind keeping them.
- Installer
More important does it have the best stratergy for running full group? When you select full group in the software does the ECU change the way the injectors are fired and if so how?
As far as I know only AEB and KME have the best method of firing injectors with full group.
Hi, yes you can use Brc injectors and reducer with LPGTECH look on the link below there is full list of supported injectors
http://imageshack.us/photo/my-images/248/lpgtech.jpg
I do not know whose method is best, but i know that LPGTech working well with full group injection.
Cheers
Cheers
WWW.LPGSHOP.CO.UK
Great info. Thanks!LPGTECH wrote:Hi, yes you can use Brc injectors and reducer with LPGTECH look on the link below there is full list of supported injectors
Cheers
- Installer
But does it change the way the injectors are fired?LPGTECH wrote:Hi, yes you can use Brc injectors and reducer with LPGTECH look on the link below there is full list of supported injectors
Cheers
Hi i have just spoken with main technician in LPGTECH, he said that full group settings will work only with slower injectors like 3ohm Valtek, because on full group injection engines, injection times are very short 2ms that is why full group setting will change the way the lpg injectors are fired, injectors are opened twice longer to be able to work properly .classicswede wrote:But does it change the way the injectors are fired?LPGTECH wrote:Hi, yes you can use Brc injectors and reducer with LPGTECH look on the link below there is full list of supported injectors
Cheers
With faster injectors like 1.9ohm BRC/HANA/Kehin /Barracuda, system should work as sequential those injector are quick enough to work with full group injection engine.
Any way LPGTECH will do the job . you just need to try it while calibration , which way is better for your engine.
i hope it's clear enough.
WWW.LPGSHOP.CO.UK
- Installer
Sounds like they have included the correct feature to double the injection times and filter out the second pulse. Worth using regardless of injector type.
Its ok I found a way around it.
I piggy-backed 1,2 and 3 with 4,5 and 6.
Then told the ECU that it was a three cylinder car.
Problem solved. All six injectors now pulsing at the same length.
I've still got to do a bit of fine tuning but it drives much better and is no longer lumpy at idle. Tomorrow I've got to fill the tank up and retune her.
- Installer
A bodge that does work and has got you out of a hole on this one.
I'm still curious as to what is actualy causing the problem
I would imagine it is not compatable with full group systems over four cylinders. It could be an ECU fault. Either way I don't care so long as the car works ok.classicswede wrote:A bodge that does work and has got you out of a hole on this one.
But it is worth noting that buying a second hand BRC system for a car with full group injection with over four cylinders might cause problems.
