Corsa: toggle switch wiring order
Rosanbo
#1 Post by Rosanbo »
EDIT SOLVED NOW
Corsa Dual Fuel, fitted from new, All I can tell you about the system is that there is a aluminium cylinder with a wiring connection about the size of a fuel filter ....which says "NECAM" on it.... which is fitted inline in the fuel line, at the bulk head in the engine compartment, about 8 inches away from the "common rail" pipe (a welded piece of sealed stainless steel pipe which feeds each injector site).
The switch for LPG is on the centre console infront of the gearstick.
I've been a bit of an idiot, I had to remove centre console and the wires on the switch and can't remember which order they came off. :?
nearest the gear stick is the LPG position and the Petrol postion is nearest the engine side.
There are 2 positions for the switch LPG/Petrol
there are 3 wires grey/Black, Red/Black, Red,Yellow
3 contacts, one nearest gearstick, one nearest engine, and one in the middle
I believe the grey is the nearest gearstick (the LPG one)
I believe red/black is the middle & Red/Yellow is engine side
Can anyone confirm please?
Rosanbo
Re: Corsa: toggle switch wiring order
#2 Post by Rosanbo »
It's sorted now.
I just had to check which one was 12V, ..... it was the red/black.
So red/black will go in the middle
and the others will determine lpg or petrol
As it happens, LPG is the red/yellow
I have not put it back together yet but all I need to do is check in the LPG position which terminal on the switch is closed circuit with the central connector and put red/yellow to that terminal.
#3 Post by Gilbertd »
A simple toggle switch? That doesn't sound original......
#4 Post by rossko »
If I recall, it's an on-off switch only, and the third wire is for the LED. There are round and rectangular types, might help if you want someone to come back with connections.
Rosanbo
#5 Post by Rosanbo »
It is an original equipment switch as illustrated in the Corsa user manual.
No worries, I know where the wires go now.
#6 Post by rossko »
Okeydoke, that should help the next person with the problem.
