van wont change from petrol to lpg
Posted: Mon Jun 11, 2012 9:08 pm
by davey1
my 2005 lpg transit changed from lpg to petrol its self while i was driving (plenty of gas in tank) and will not change back to lpg now
Re: van wont change from petrol to lpg
Posted: Tue Jun 12, 2012 9:15 am
by Dualtech
Hi, does it behave as if it has run out of gas?
also, which system is fitted?
Cheers, Mick
Posted: Tue Jun 12, 2012 8:28 pm
by davey1
havent had the van long and never ran out of gas.....but i assume its similar because it swapped from gas to petrol automatically and wont swap back. when it happened the switch on dash didnt light up when i pressed it,,,,i checked fuses and one was blown so now light on switch comes on but it still doesnt swap over to gas......not sure what type it is
thanks
Posted: Wed Jun 13, 2012 11:52 am
by Dualtech
Would be worth checking that the solenoids are opening, should be one on tank and another under the bonnet at the filter shut off valve. Its possible that a bad coil could have caused the fuse to blow. If you power up the coils with 12volts then you should hear a click from each one. If there is no click then the valve isnt opening and the lpg cant flow.
