jseaman wrote:I'm hoping for a little advice on an issue I have with my car. It's a 1996 XJ6 (3.2 straight 6) and it is fitted with a Stefanelli multipoint system. I'm a novice when it comes to LPG and have an issue with my system that I'm hoping someone can help with. The car runs perfectly on petrol but when on LPG, if I use more than about 20% throttle it is likely to trip out and switch back to petrol. It's usually worse under load and when the auto box changes it is likely to flick off as well. If I drive steady then I can easily get up to 70+ mph and it's smooth as silk but it is very difficult to not use more than 20% throttle.
There is a restriction in the gas flow so the pressure drops under high demand and it changes back to petrol.
jseaman wrote:My vapouriser is covered with a piece of shiny bubble wrap! The first thing I did was remove this but it made a dramatic difference to the warm up time (it was taking >10 minutes to switch to LPG). With this in place it switches over as soon as the car is up to temperature. I have highlighted 4 bolts which protrude from the vapouriser, should I touch any of this stuff?
The bubble wrap has been put there as some sort of insulation either to compensate for poor coolant flow (to make it warm up quicker) or to protect it from excess heat (which shouldn't be a problem as it needs to be nice and hot). You don't make it clear whether it changes over earlier with or without it, but leave it in the state where it changes over quickest.
The three bolts on the vapouriser itself should not be touched but the one furthest to the left on your picture is the liquid phase filter and front shut off solenoid. This is almost certainly the cause of your restriction and needs cleaning/replacing. With the system switched off, slacken the input pipe union to this unit slightly to release gas pressure in the pipe running from the tank. Liquid gas will escape for a while, quite a while as you can have up to half a litre of liquid in the pipe which will make about 125 litres of gas vapour. Do it outside in the open and not over any drains (as the gas is heavier than air and will pool in them), preferably on a windy day to diperse the vapour. Then you can undo the bolt and take the filter element out. Make sure you tighten the input union again before you try to run on gas again.
jseaman wrote:What is the part in picture 3, it looks like some sort of accumulator?
If it is in the hose from the vapouriser to the injectors, it is the gas phase filter. Clean/replace. This is much less likely to be the cause of your problems.
jseaman wrote:Is it OK for the LPG injectors to fire into the inlet manifold via a piece of rubber hose as shown in the 4th picture? Does this not screw up the spray pattern?
As Ross and Simon said, it's a gas, it doesn't have a spray pattern. Remote injectors and hose is normal.
jseaman wrote:Where would I find a filter in the system?
You already have......
