WANTED - Zavoli injector inlet manifold ferrules.
himselfunknown
#1 Post by himselfunknown »
I have bought a secondhand Zavoli sequential kit, but have discovered that the ferrules that screw into the inlet manifold are missing.
Does anyone have a set (of 6), or know of a supplier who may stock them?
The conversion is intended to go onto a 210bhp engine, so will need to be sized accordingly (or be able to be drilled out).
Cheers.
Dualtech
Re: WANTED - Zavoli injector inlet manifold ferrules.
#2 Post by Dualtech »
Hi, what size injector pipe/spuds does it use? If its 4mm then they available on tinleytech.co.uk/shop
#3 Post by Gilbertd »
You don't size the ferrules, you size the nozzles on the injectors. The ferrules come in one size.
