Converter to run Blos carb?
Posted: Sun Mar 04, 2012 10:04 am
by 131
I've got an LG B2 simple converter supplying a gasresearch throttlebody. I've got a Blos carb I'd like to fit, but I've been told I require a complex converter to run the blos, something that has adjustment for idle mixture/pressure. What brand/type of converter would suit what I'm trying to do?
Re: Converter to run Blos carb?
Posted: Sun Mar 04, 2012 12:30 pm
by e301988325i
Need more information of engine size/ configuration and power output to properly advise. OMVL R90e vapouriser is a fine product (what I use) and comes in versions to suit higher power outputs.
Posted: Sun Mar 04, 2012 9:14 pm
by 131
An '82 Fiat 2 litre 8v, about 120hp, with plans for an Eaton supercharger puffing 7psi. That was another question I forgot to ask, is the Blos ok for boost? And the converter will have to be able to take a boost reference.
I've been running one of these throttlebodies on it for 5 years:
http://www.gasresearch.com.au/
I can run it with boost, simply have to fit a converter with boost reference. But I've got a Blos carb and have read good stuff about them. It's just hard to find someone that actually uses them.
Posted: Sat Mar 10, 2012 11:40 am
by e301988325i
The BLOS has to go before the blower, which means the blower would be compressing the fuel air mix and your intake will be full of compressed fuel/air mix :!:
Posted: Sun Mar 11, 2012 2:48 am
by 131
e301988325i wrote:The BLOS has to go before the blower, which means the blower would be compressing the fuel air mix and your intake will be full of compressed fuel/air mix
Hmm, thanks for that, it has to be draw through, not blow through. I don't want a small bomb hanging off the side of the block waiting for a backfire. I'll stay with what I've got I think and upgrade the converter so it will take a boost reference.
Posted: Sun Mar 11, 2012 9:56 am
by e301988325i
