LPG Professional in South East area.
arielowaty
#1 Post by arielowaty »
Hi guys.Have been on forum quite while and i had a thought to introduce myself.
If anyone need a hand please do not hesitate to contact.
Been with LPG over 16years now.Loads of experience.
I will try suppoprt and help forum with my knowledge as much as i can-but due to lack of time -just in case- be patience.
If that post is in wrong place forgive.
Specialize in:
BMW :) Main dealer facility.
-Prins
-Lima
-BRC
-Stag
-Zenit
-Autronic
-Nicam Koltec
-Bigas
Any lpg system.
AJ Autogas
Unit 2,Keel Court
Medway City Estate
Rochester
Kent
ME2 4LY
01634 297 622 or 07731155386
Need any advice just ask :)
Spinglehoffer1
Re: LPG Professional in South East area.
#2 Post by Spinglehoffer1 »
Hi looking to convert V6 Toyota Prado SWB, any suggestions, been offered reasonable price for a stefanelli system but new to lpg so never heard of them, also concerned about tank position and size as i want tank underslung to maximise space?
Reshard1977
#3 Post by Reshard1977 »
I just bought a 1999 audi a3 1.8t quattro. Being an old car i didnt pay much for it, so i'm looking for a good value for money kit to go in. Any recommendations?
Dualtech
#4 Post by Dualtech »
Think the Toyota Prado can have a cylinder tank mounted underneath at the back behind the axel, would be worth a look with a tape measure. Stefaneli has been around for a while, its a Italian system so should be good although I havent had much experiance of it myself.
I would suggest Flash Lube is a must on a Toyota. :)
As for the audi, It may be a '99 but would still be best to fit a multipoint system, are you looking for the conversion to be done for you or a good diy system?
Im sure there are plenty of us installers on here who will be happy to quote :D , or you could take a look at
http://www.tinleytech.co.uk/ if you fancy having a go your self. :D
Cheers Mick
Just fix it
#5 Post by Just fix it »
I wonder if you can help ??
I have installed an ag centrum zenit system on my BMW e38 735i. When I plug the unit into the computer to set up I can see the petrol injection times around 4ms on each cylindr but nothing is shown against the lpg injectors. Do I need to input the lpg times under the config menu or should they come up automatically based on the petrol ecu times.
When the system switches over to gas the engine cuts out. The screen shows C.OFF against the gas window.
I have disabled the lambda sensor, as the ecu only has a single output is it ok to connect to one side can you advise which connection to use on the sensor.
Cheers
John
