Do you agree i should drop the reducer pressure a little?
So tomorrow morning i shall drop the reducer pressure.1-1.1bar
Go back to a base map.
Turn off adaptivity.
Set the pressure in the ecu in the config to 1.4bar
Do an auto calibration.
Read the trims and adjust the map adding 10% across the board,reading trims and then adding or subtracting in blocks of 5% making sure to have a nice flow and no gaps?
Im assuming until then im ok driving it on gas?Got to pick the missus up thats all.
