Its Lpgtech Shark 1200 very similar to Tomasetto Alaska. just tried few times to check if it works reducer newer freeze up.sportston wrote:What reducer do you use with it? Does it freeze up?LPGTECH wrote: Hi i have LPGTech ECU in my company car Citroen Berlingo 1.4 . i have tried to start it on cold and it works, just press and hold gas switch while starting. But on the beginning because gas is to cold engine shakes a bit but only for seconds.
if you need any info about LPGTECH just let me know i am installing and using this system more than one year now.
cheers
when engine is warm its switching over in 2sec, you can set it up switch over time in settings.
