Gilbertd wrote:LPGC wrote:
If more of the point of the sticker was aimed at making it clear the vehicle was LPG converted, had a gas tank fitted etc, rather than reading 'X Autogas' as the main content, such stickers would make more sense from a safety aspect.
As has been mentioned a marking on the number plates is compulsory in Australia but there has been objections to that as it can make the car more susceptible to arson attacks. I wouldn't want to promote a prominent sticker or label for that reason
Agreed mate, plus I agree to your earlier reason(s) for not wanting stickers / signs on cars... They look @!## and are used as a means of free advertising by installers, for various reasons some customers would be put off if they had to have a sticker on their vehicle, bad for the trade.
On top of this, MOT man is expected by DOT to find an almost average number of faults of each type, i.e If he tests 100 vehicles yet fails none of them on bulbs DOT may suspect that he is passing vehicles with failed bulbs and telling people 'just get that bulb sorted mate'.
or, as in the case of one tester I know, he simply fits a new bulb and charges the customer an extra couple of quid. He was questioned on why he didn't fail on blown bulbs and was told that what he was doing was fine but he should issue a fail on a blown bulb and then show a retest that passes.
Well, the DOT did notice that the tester wasn't failing enough vehicles on bulbs - they would also notice that the tester wasn't failing enough vehicles on LPG matters too, this demonstrates how the MOT system and individual testers are thoroughly overseen / audited / the system standardised... and helps prevent testers from passing what they shouldn't.
Gilbertd wrote:Wouldn't it be amusing if, after all your efforts and arguments, the system of a check by an MoT tester was finally implemented and nobody failed anything?
Yes mate - I too would have to laugh at that!
On a serious note, though, your answer doesn't answer my question and I can't see that happening due to the implications of the above.
One of the points you didn't reply to, part of the same thread as points you did reply to was this
LPGC wrote:
To put this another way in an exaggerated example - UKLPG get to check 33% of what might be expected to be safe installs but get to check none of the installs which might be expected to be unsafe.
What sort of a reply did you expect? Yes, you are probably correct but I wouldn't expect a DIY installation to be any worse than a done-in-a-day installation in all honesty, in fact, I'd suggest that anyone that has the confidence in their own abilities and the skills to do an install would do a pretty good job. They'll all be inspected at an MoT within 12 months anyway so what point are you trying to make?.
I'm trying not to be pushy, but you will remember recent comments about repetition and my explanation of why I sometimes feel the need to repeat myself etc... I've reminded you a couple times about the unanswered points I've made am repeating myself with reminders now. Would have expected an answer to most of those points if you were being true to form and also disagreed (I'm not saying true to form you'd disagree - note the 'and'!). You just agreed to one of my more recent points but I wonder if your agree with those points in the previous post I've again referred to? I could quote myself on the full post I refer to if you like or if you're not sure which post I refer to, then delete the re-quote when you have replied?
DIYers come with all sorts of attitudes ranging from, mostly like you say, highly positive with the skills to match / to outright 'chuck it on to run on cheap fuel' arrogant types that might, at the same time, not have the skills / knowledge, adding to the arrogance. If you were to do a DIY install I would expect it to be of the same or a higher standard than the average pro, done in 3 days install but some DIYers don't have the skills, knowledge, attitude or are willing to allocate enough time to o do a good job. I would agree with your comments on done in a day pros. It is the bad attitude / unskilled / un-knowledgeable DIYers and done in a day pros that are mostly likely to do unsafe installs and those same groups are also most unlikely to submit vehicles to UKLPG checks - we seem to agree on that.
There are academic people that could memorise all the facts, figures, code of practice, standards and know all the theory, yet fall short when it comes to doing the practical...
Ah, you've met our Health and Safety manager then? Paid a ridiculous amount of money to develop and implement H&S policy yet although she knows all the regulations inside out is totally impractical and also one of the most accident prone people I have ever met! Fortunately, she is also aware of her own shortcomings and wouldn't attempt anything practical (she just writes policy that tries to stop the rest of us, that do have the ability, from being able to do it either). An example is that all our company vehicles have had the spare wheel, jack and wheelbrace removed and should we get a puncture we should call the AA to get them to come out and recover the vehicle as we aren't qualified to change a wheel. The only people that have company vehicles are the engineers and there's a clue in the title. My daughter changed her first wheel at the age of 17 by reading the owners handbook FFS!
Hehe, we agree on that, then!
SimonHobson wrote:<above post
I had the same experience when I first started out.. all seemingly cloak and dagger. Suppliers didn't want to supply to me directly... if LPGA found out they might have kicked said suppliers out of LPGA, plus suppliers didn't want to give tech support to DIYers (we're all classed as DIYers on our first few installs). What happened was, supplier passed me onto one of their staff, who sold the parts to me at a price including the staff member's markup, the staff member gave all the usual tech support supposedly in their own time but this included much of their work time. The idea, looking back, seemed to be so supplier could distance themselves from me when I was first starting up. The situation was a world away from what we have now, you couldn't buy parts even off the internet unless you were an LPGA member, suppliers and installers alike super hyped LPGA, it was open season for some (most) installers to charge ridiculously high prices and for some suppliers to do the same. This was effectively a 'closed shop' situation - law didn't make for the situation, the trade body, it's members and general sheep-like attitudes did.
