The pipework does read to be a pain, always expected it would take longer than LPG pipework but would expect to speed things up with growing familiarity (of components and practices)? Not to the same speed as fitting LPG piping but for sure to get the whole job lot conversion done in maybe 4 days altogether? For sure an otherwise busy with LPG conversions pro like myself would lose out in the short term due to taking too long due to being unfamiliar, but would then get quicker and charge only the extra time when up to full speed on the CNG conversions?
Oh for sure, and I suspect you've done so many of certain vehicles, you're bored rigid to convert yet another Range Rooney? You'll do the things in your sleep. The job is going to take you longer but once you have it down... only it's a moot point. Can't see a queue forming at your door for this work.
Instead of spending a lot of money on suck it and see pressure senders, why not buy a generic pressure sender and interface it's signal to your choice(s) of LPG ECU(s) using a cheap microcontroller system such as Arduino that has onboard AD and DA convertors, plus maybe some very basic electronics. Doing this you could probably use any pressure sender you ever bought with any LPG ECU and expect to get a more accurate gauge than an LPG system gauge.
In the finish, anything can be done, and that's exactly what I did last outing. After leaving to blind-luck importing gauge No.3 I gave in. I use what was sold to me as an AEB806, running Full 5V>0V Empty. Now set to displaying to the stock resistive gauge in my daily-driver-classic. It's calibrated to within an inch of its life,such that 'empty' really is empty. Yet, oh dear christ... the pain in getting there?... Importing three-gauges, messing with them, taking them off again. And the cost. With LPG it'd be 10 minutes with £15 quids worth of AEB1050, and be done. Some imported from the states, others Europe, for a fuel-gauge my bill's over ten times that. When the whole point in this was to save money? And I twist on...
If indeed it is a 90Ohm, I'd have been very, very happy with what I now see on eBay, see piccy.
CNG is common in many 3rd world countries, surely the piping tanks and senders are not mega-bucks where available in those countries?
They're not. And its' helped by for example India and Argentina as the big markets, Maruti (Suzuki) make NG stuff straight off the showroom floor. For conversions, no doubt most of it comes off the shelf, much as LPG kits for a Range Rooney does here.
Nothing in stainless, they'll run in a dodgy out-of-date cylinder and bang the rest in. It's where the expired German and Italian cylinders wind-up. With the added advantage that this work adds to the heap of Youtube videos with some horrific accidents. You might see why I refuse to play.
This work to this standard would be pricey and time consuming anywhere. It restores the install to the same, or above, the standard of the Volvo factory-fit. I can see ways to short-cut this job, I'm rather forced to exceed the standard of the Volvo fit because my replacement Luxfer cylinder has different, and therefore far pricier fittings to the original factory Raufoss jobby. That changes pipework, and the install, and puts the time, and cost, way up. If I used that Raufoss, I could be driving around this minute, and wouldn't be doing this work. I've only recently disposed of my 5 years out-of-date, Raufoss cylinder. Use that? Nope, I think not.
It's counter-intuitive, but done right, there's a heap of evidence to suggest that LPG is safer than Petrol. People simply don't question the more familiar risks associated with petrol. Broadly speaking, petrol is very dangerous stuff - there's a heap of increasingly horrific Youtube accidents to show for it.
NG cylinders get tested in train-crashes, try that with a Stako? I can't see petrol safe in a mothers'-meet, pram-fight? For me, a proper NG install exceeds the safety of LPG. For fear of sounding a little pompous, I'm happy to take the time to be sure it is.
The other impetus for this is that, for insurance purposes, I don't want to be found wandering into the modified car arena. Keep it stock, or as the insurers describe, 'with periodic maintenance, like-for-like, parts equivalents'. Such that, it's nailed to the floor. If, god forbid, your friend and mine, our loss-adjsuter ever does knock; he won't find anything with which his client can wriggle on. My advice: keep 'em skewered. e.g: just in case they deem to judge my change of reducer etc 'a modification' - I always declare this factory-fit as a 'conversion'; when to the pedantic last letter, it never is. From experience with insurance companies, they'll try it on if they can. I'd rather appear as some smug a*se here, than stand in white-faced shock as some actuary announces 'yours truly' uninsured.
Branded Atiker, pix of the first CNG Gauge I've ever found declared as 90 Ohm. As is tradition, the Atiker web site keeps the output blind, thus how the seller warrants these as 90 Ohm, is not clear. But there it is. Cheap too.
"Get 'em whilst they're hot..."
- 90Ohm-CNG-Gauge-Atiker-Manometer.gif (56.54 KiB) Viewed 5251 times
