If the plotted points and lambda readings are anything to go by (and they are a fair indicator) it seems calibration and fuelling was fine in the conditions of your run in the video.. looking a lot better!
You didn't click on 'clear the gas map' before the run so the plotted points and the line it draws between plotted points will take time to change during the run. Watching the position of the crosshairs at around 12ms it seems if the run were longer they would eventually match the plotted petrol points so I don't think you've overdone any adjustment you made at 12ms.
Throughout the test the engine was running in closed loop mode (or at least most likely was) because lambda flicks all the time during the test and engine rpm (and possible engine load / manifold pressure) probably isn't high enough for fuelling to switch to open loop mode. If you put your foot down at high rpm it will run in open loop mode, you should check/set multiplier to give rich but not too rich mixture under those conditions - You may find pinj increases to a bit above 12ms as the engine comes more 'on cam' at higher rpm, so you may have to change both the 12ms and 16ms multiplier points (and if you change the 16ms point it would be good practice to 'follow on' and anticipate/guestimate the shape of the line towards the multiplier point at 25.5ms). Going only on the video (haven't seen readings at higher rpm higher engine loads) might suggest dropping multiplier at 10ms by a point and at 12ms by a couple of points, but would be better to see higher rpm readings first.
The shape of the map now (in your video) is a lot more like the shape I guessed than the shape in your last screenshot above
What rpm correction figures do you have dialled in now (during the test)? Is temp correction still a flat line or did you adjust it?
At around 50seconds rpm is around 1100, pinj is 1.9ms, ginj is 3.5ms. The 3.5ms is a bit low for these injectors - During engine warmup from cold under no engine load conditions if you hold the engine at fast idle does it run OK?
Depending on answers might suggest seeing if you can turn pressure up a bit, though unless it's a MJ Extra reducer (usually adjustable up to 1.7bar) or a very recent MJ compact reducer (those produced in last few months have same range of pressure adjustment as Extra, earlier ones max out at around 1.35 bar) I expect it will already be set at just about it's maximum pressure.
When the engine is fully warmed up if you hold fast idle (1100) and switch between petrol/LPG, LPG/petrol does the 1.9pinj increase or decrease? Does lambda voltage hang low or high for a moment?
