Depends on the pump - some do, some don't. You will also find some you have to release and try again if you press it too soon. Usually giving it a press for about 30 seconds, if you get nothing then, release and try again usually does the trick.Pinger wrote: Thu Mar 05, 2020 6:24 pm I now have a full tank of LPG - less 50 or so miles worth of running. Relief!
A bit of everything discussed contributed to yesterday's no fill. Not least the dead man's handle that is the 'button'. Yes I knew it had to be held for continuous delivery but I didn't know that releasing it even momentarily required a reset by the cashier. We live we learn....
Changing the filler type and relocating isn't a bad idea. Haven't decided yet about tank relocation but the filler is probably worth doing irrespective of that.
Car runs more or less fine on LPG but at higher rpm seems less happy. Some investigation required I think but as yesterday was the first I'd driven it on the road there's a few other things to attend to first - such as a steering shimmy at the very end of a heavy braking stop.
Anyway, one milestone is passed (car on road and running on LPG) and the advice here helped massively with that so thanks to everyone (all three of you!) who helped. Massively appreciated, thank you.
Sounds like your filler is past its best possibily though, so Richard's advice on changing it would be worth considering if you keep having problems.
You have it working, thats the main thing!Pinger wrote: Thu Mar 05, 2020 6:28 pm Brian_H. If I'd posted just minutes sooner I could have saved you a lot of typing. As you will have read, it now fills and is filled.
Nonetheless, your proposed test methods are noted for future use - cheers.
