Page 3 of 3
Re: Lexus V8 - OMVL not switching on - please help
Posted: Fri Jun 22, 2012 12:33 am
by andy evans autogas
Always tick the default box after setup that way you can control the stepper above or below a fixed value that way if an o2 sensor does go wrong the system can't drift to far out. Idle steps above and below & out of idle are usualy set at 25 &40 above & below
Posted: Fri Jun 22, 2012 10:13 pm
by 4x4xfaz
I followed the brown wire (as well as a purple / lilac wire) from the control box plug, it goes to the vehicle diagnostic socket (not the OBD plug - most Toyotas have a "DIAGNOSTIC SOCKET" as well as a OBD plug) it looks like it is connected firmly. ( I guess I could try a volt meter and see what reading I get)
So the brown wire is not connected to the coil - but the diagnostic plug - OK?
Posted: Sat Jun 23, 2012 8:41 am
If that socket has a rev counter feed to it, they've probably connected to that. As long as it connects to something that has regular pulses on it to tell the controller that the engine is running, what you actually connect to is not important. Does that socket have a rev counter output and does it work?
Posted: Wed Jun 27, 2012 10:04 am
Posted: Wed Jun 27, 2012 10:32 am
by mat_fenwick
Very useful website!
