Re: UKLPG comments
Posted: Tue May 27, 2014 9:57 pm
I was fully aware of that. But I think we all know Simon is the one having problems.......
UK LPG fuelled vehicles and alternative fuel forum. LPG Conversions, Refuel Stations, trouble shooting and more.
http://lpgforum.co.uk/
Oy! Which Simon? What problems?Gilbertd wrote:I was fully aware of that. But I think we all know Simon is the one having problems.......
To me, to you, to me, to youGilbertd wrote:LPGC wrote:
See if you can stop UKLPG and their members from implying points and making claims based on numbers they cannot know.
Only when you stop doing exactly the same.....
Maybe you don't know that the installers that generally stick to the same system components contact other installers that are familiar with a wider ranger of systems when they convert certain vehicles that they know are going to be a bit more demanding... i.e. What would you fit on this vehicle mate? Might not be a great idea to fit say V34 injectors on a supercharged Rangerover even if you do praise V34s all the time on the forum. The same goes for, say, CPR reducers. We can extend this to ECUs in some cases. If you don't then know much about, say, other injectors performance or even have a yardstick to compare you need to ask advice from those that do. Only by comparing components do you get the yardstick. Better to sometimes fit better components than you usually might on medium demand (in terms of components) engines like say a Subaru Turbo, you might know that the V34s will cut it on this engine but you might try some different injectors that respond a bit better. When you see that these other injectors flow just as well with nozzle sizes 0.5mm smaller than V34s you take note. When you see that the map on these injectors is flatter that the map you know you'd have with V34's you they are more linear. So you might decide to fit those injectors on a SC Rangerover and since you've also done similar with reducers you might know that instead of 2 x CPR reducers you could fit a single reducer of a different make but back to the injectors again you can start with nozzles a bit smaller than you'd expect because this other reducer will only dial down to 1.2 bar but will go up to higher than usual reducer pressures... And to put if from another angle, Ford don't fit the same spec injectors and fuel pump on a Fiesta and a supercharged V8! A wide approach makes you better and more rounded at your job, also makes you more likely to have equipment / ability to work on a wide range of systems that might be brought to you for repair. Would you want to be a vehicle LPG fuel system expert or just an expert on just a tiny subset of vehicle LPG conversion parts?Gilbertd wrote:Bugger off, I'd pick a decent system and stick with it then if it doesn't behave as expected I'd know I'd got a faulty component and not something that was supposed to behave that way. I might experiment with odd bits and pieces from here and there on my own cars (or the wife's) but not on something I was being paid to convert.
I think the number of insurers concerned with this private database are low and that is the experience of most people on this thread. I suppose it's where you see the numbers are and how much of a problem you think it would be to put the car on the database in future if need be. I know that it is as simple as making a phone call but I won't make a call to spend money until necessary. Insurers can ask for what they want - there might be an insurer that refuses to insure a vehicle unless it is painted luminous orange 'for visibility', you won't go out and paint your car dayglow orange in case you ever want to use that insurerGilbertd wrote:While some insurers want a car to be on the Register then yes, I would ensure that every conversion I did was on there
I got an email from a friend of a friend. He'd bought an LPG converted Land Rover and his insurer demanded it go on the register. It looked like a DIY conversion and needed a few details sorted (nothing major), and I suggested he just send my certificate rather than ask - so he sent my certificate and they were happy.Gilbertd wrote:I think the number of insurers concerned with this private database are low and that is the experience of most people on this thread.
It had. But then the topic resurrected itself by going off topic in a completely different thread so one of the mods merged the last 5 pages from that one into this one rather than leave it where it was.SimonHobson wrote:Just when I thought this thread had died :roll:
That's what people do when presented with a long spiel. They look to the parts they know about or are interested in. If those parts are wrong, the whole spiel is dismissed. You'll know this for yourself.LPGC wrote:I'm not sure it does really answer my point Rosko, because again you have selectively quoted from a longer point that I made and my point now appears out of context.
Where did I say that?LPGC wrote:let's use Rosko's figures: 20% of installers are UKLPG members
Who said that?LPGC wrote:70% of installs are on UKLPG's database
Okeydoke, motives and methods clarified; destruction of only existing safety scheme, then we can think about what's next. Brilliant for the trade, fantastic for the consumers.LPGC wrote:Sometimes it is easier and more sensible to pull down and rebuild than it is to repair the existing house.
Literally years this has been going on. Sometime never I suppose.LPGC wrote:But maybe Rosko has good reason to prefer people to dive straight in and lobby the government with a proposal against the trade body that he seems to hold so dear, rather than them discuss it with him and others in the trade first?
Well done to BRC, I never saw the advert and this is the first I have heard, did UKLPG pay for the ad?rossko wrote:Good guess about 'Dave' TV
viewtopic.php?f=33&t=9733&hilit=tv+advert
Not really, I look at all points made, maybe you should reply to points you reckon you're not interested in... There won't be many points that are not relevant.rossko wrote:That's what people do when presented with a long spiel. They look to the parts they know about or are interested in. If those parts are wrong, the whole spiel is dismissed
LPGC wrote: 70% of installs are on UKLPG's database
Who said that?
Ok Rosko, here you implied 33% of installers are UKLPG members. But then later you went on along with Dai's / Tubbs / Gilberts figures which seemed to be more like 20%. 33% is of course still a minority of installers.rossko wrote:Pick an area you know, estimate how many installers you know. Use the map to see how many are UKLPG. Now you can get a ratio, say 2 to 1, and the number of UKLPG in that area. Then you can multiply up to get a national figure, with say 300 other installers to 150 UKLPG.
Again out of context, out of balance. In the same thread I said I wouldn't be concerned about UKLPG or installers being members of UKLPG if there were no false or misleading claims implied due to UKLPG involvement. I said I might become a member if I believed the claims to be true. While false claims exist I would not want to be a member of the organisation, while I think UKLPGs scheme does not 'ensure safety' I will not want to be a member. Instead I have suggested an alternative scheme and as yet there has been little discussion on my suggestion. I wouldn't be concerned if UKLPG's house was left standing if right beside it there was a new house (safety scheme) that was fit for purpose and endorsed in legislation to ensure 100% of vehicles were inspected. Nobody would take much notice of the old house then, you could use UKLPGs logo on your letterheads and nobody would care because there would be far fewer pretenses of any advantages due to UKLPGs involvement.rossko wrote:LPGC wrote:
Another link that does as much for my points as it does yours.rossko wrote:More spoon feeding for anyone genuinely interested
https://www.gov.uk/government/policies/ ... regulation
Understand the system you seek to change.
I've brought up the same point before mate. Sometimes an insurer will ask for proof of install, meaning they want to see a receipt or something that shows the system was fitted by a competent person. UKLPG / LPGA do not have a comprehensive list of competent people, they only have a list of their members. Some UKLPG members take such a request and pretend the insurer is asking for database registration or a green LPGA cert when all that is asked for is a receipt from the installer.SimonHobson wrote:So even those that say they require UKLPG certification often don't when it comes down to it. Of course, most people will never find this out as they'll take the initial requirements at face value.
Maybe the insurance company staff are confused and ask for a certificate when really they should be looking at a database. I would argue a bit of paper and a computer database are very different things and not so easy to confuse. Or maybe some insurance company staff and some owners of LPG vehicles confuse asking for a certificate from a competent person with asking for a certificate from the long since ended LPGA. I would argue that a bit of paper and a bit of paper are similar things and much more likely to be confused. Raises another point - Bosses of insurance companies and the public are not very sure about what exactly is required regarding LPG converted vehicles.Tubbs wrote:UKLPGA haven't given certificates for a long time (+5 years, maybe longer) it's all on line. Even when you do register all your vehicles you still get the odd insurer ask for a certificate because that's what they have been told to ask for.
This is the customers convenience point which persuaded you to join UKLPG? I can see that point but would say that in 3 years time if the customer wants to use one of the minority of insurers that take note of UKLPGs database they could easily then get the vehicle on UKLPGs database. I don't see why you've mentioned 'surely they just want a gas conversion that works' because UKLPGs scheme makes no claims of good performance on LPG or quality of install. By paying for the database registration today they are supporting UKLPG today and it is UKLPG whom have gone out of their way to restrict customer insurance options without justifying that with a viable safety scheme in the first place. You haven't said much about your thoughts on UKLPGs impact of safety in this industry, how your customers went about insurance before you recently became a UKLPG member or your thoughts on UKLPG in general but I know UKLPG don't provide the scheme that you would want or maybe even expect - UKLPG's scheme not turned out as you would have liked mate?Tubbs wrote:Point being though. Why get your customers to fight your battles for you ? Surely they just want a gas conversion that works. Attracts no hassle from insurance companies when they go compare for a cheaper quote 3 years down the line because their no claims has been maxed out and capped by the previous company ?
Well, if you'd had zoomed right in on the dot you'd have seen it was a James Bond style micro-dot and contained a full length post!Gilbertd wrote:Blimey, a post from Simon that doesn't take a week to read!!!
What's up? Running out of arguments?
Oooerrr I hope not - Thought I had destroyed the evidence!rossko wrote: I thought this forum used to display when posts were edited.
There's been lots of discussion on it but unfortunately you are suggesting your alternative scheme in the wrong place. Nobody on here is in a position to change the current system, so why bother keep repeating it? You've suggested it, there's been a few comments about being careful as someone may decide that it becomes a full blown IVA test instead but, as far as I am aware, nobody has been totally against it. So suggest it to someone that is in a position to change things.LPGC wrote:Instead I have suggested an alternative scheme and as yet there has been little discussion on my suggestion.
Yup, that's right, they call it 'light touch' regulation. Current and recent past Governments have been against regulation, it would mean they would have to employ more people to ensure the regulations are being adhered to, not something they want to do. They prefer to let trade associations come up with their own codes of practice and enforce them. The view is taken that a trade association knows more about their own specialism that they do and it means they don't have to employ consultants at a huge sum per day to investigate an industry for them. In the case of LPG conversions, there hasn't been a huge increase in the number of vehicles spontaneously combusting while they are driving down the road and nothing has burst into flames following a 5 mph hour impact (that only happens in films in the States), so the safety regime operated by the existing trade association is obviously working.LPGC wrote:So it seems the government prefer to allow industries to be self regulating and will only bring in government regulations when it makes sense to do so
at which point the owner of the car goes, "Eek, so all these years I've been driving around in a car that may not be safe?" Why should an owner be forced to shell out more money to confirm that his conversion is safe 3 or 4 years down the line? He wants an assurance when he picks it up. Before you chime in with, Ah yes but the fact that a conversion is on the Register is no guarantee that the conversion is safe because it could have been registered on the strength of a phone call, that is beside the point. Your customer wants to know that all bases have been covered and his conversion isn't going to cause him grief. Having to get it inspected at some point in the future because he wants to save a few quid on his insurance, is going to be a cause of grief.LPGC wrote: I can see that point but would say that in 3 years time if the customer wants to use one of the minority of insurers that take note of UKLPGs database they could easily then get the vehicle on UKLPGs database.
Could've fooled me......LPGC wrote:Proof read my post, as I generally do
Did I, when was that?LPGC wrote:But then later you went on along with Dai's / Tubbs / Gilberts figures
Which 70% figure - you said "70% of installs are on UKLPG's database" but the document you point at doesn't even mention database or register. You don't read things properly, crikey its three words and you misinterpret it.LPGC wrote:Since posting the link you haven't seemed very willing to accept that the 70% of installs figure is in reality any lower.
Oh Simon, you can be such a burk.LPGC wrote:Another link that does as much for my points as it does yours.
Quite right Ross, all I did was use Simon's figures which were his interpretation of the UKLPG figures. This is what I actually said which boils down to saying that I think the UKLPG figures are probably about right. But of course it all depends on who you class as an installer......rossko wrote:Did I, when was that?LPGC wrote:But then later you went on along with Dai's / Tubbs / Gilberts figures
When did Richard G produce installer figures?
You'll understand that when you make stuff up about what I said or did, I need a bit of a pinch of salt for the rest as well.
Gilbertd wrote:Blimey, like buses tonight. Just finish writing a reply to one of Simon's small novels and another one comes along.......LPGC wrote:So if UKLPG had 150 members in 2010 (when the letter seems to have been written), and UKLPG members do around the same number of conversions each that none member installers do (and I think this is a generous assumption) then according to UKLPGs letter to the government there were only 64 installers in the UK that were not UKLPG members?That must have been 63 not including me then?
But here goes. So that would give around 260 installers in the country. How many are there in your area? How many in mine? Within a 30 mile radius of me I know of 3 (one being one of the recently set up Polish ones). How often do we get people on here asking for an installer in a certain area. Do we give them a list of 20 or 30 possibles to try all within spitting distance? No, there might be one or two and they might still be some way off. I would say that 260, if anything, was more than there really are.
There's going to be the odd garage here and there that do the odd conversion now and then but it isn't their main area of work. Would you even class them as installers? Because if you did then you'd also have to include the DIYer who did his own car and has then done a couple more for mates.
Page 2Gilbertd wrote:Close but not quite. It isn't Government approved, I don't think it's even Government acknowledged (In fact, if you search the Direct Gov website for LPG conversions, you'll find no reference to UKLPG or anyone else for that matter). It's a commercial organisation that have started out the right way by producing CoP11 to make installs safer. It's just that they then seem to have let the power go to their heads and act as though they are a regulatory body, which they aren't.demonicwillow wrote:its a gvt quietly approved scheme for some clever money making businessmen giving more power to insurance companies to withhold payouts, gvt approves it but dont have the responsibility of setting up, running and paying out for testers but leaving the money makers alone to regulate themselves and do what they want,
I was recently slated for confusing the word standard and the word Standard, and for implying the word 'regulations' has anything to do with laws. Here is an example of somebody else using the word 'regulation' as meaning a set of laws...Gilbertd wrote:The story put out by UKLPG that you won't get insurance without their registration is patently wrong. Many people have insurance without, some have a certificate issued by a 'competent person', with or without a UKLPG logo, some have on the basis that the car is shown on the V5 as being Petrol/LPG. My Saab was shown as petrol on the V5 but the previous owner had a LPG Safety Report done on it by an installer. This report was perfectly adequate for my insurers although not good enough for DVLA to alter the V5. They wanted a copy of the invoice from the installer. Not a UKLPG member installer, just the installer. Equally, the V5 for my P38 showed the fuel type as petrol when I got it. My insurers asked if I had a certificate but were quite happy when I told them that it had been done before I got it and I didn't receive one with the car. The fact that it had passed the MoT test running on LPG was good enough for them. In fact, that was good enough for DVLA too. After my last test, they sent me a revised V5 showing the fuel type as Petrol/LPG.
So, I agree that the publicity put out is tantamount to scare mongering but other than that, while the situation remains as it is, I don't have a problem. It just makes me wonder why LPGC has such a problem......
SimonGilbertd wrote:Correct on all points, but if you were to build your own kit for your own car, then it wouldn't be legal. As the installation does not comply with the BS EN standard then it invalidates Construction and Use Regulations. In theory it shouldn't be possible for it to pass the MoT test but in practice it probably would. If however, it was involved in an accident and inspected by an insurance assessor who found non-E67 marked components in an LPG installation then you can be sure that they wouldn't pay out at the very minimum.
Tubbs wrote:Lol. !
There is only one small issue with using me as an example ...
I'm not a UKLPGA member
