Stag 300 plus, No petrol injection ERROR
Re: Stag 300 plus, No petrol injection ERROR
#21 Post by LPGC »
dozz wrote:I swapped the wiring on the original lanrover injector plug. The red wire I am struggling with. I thought that maybe the cause of my issues so temporarily I'm connecting it directly to the battery while I try and work the problem.
That should be fine.
Regards not seeing petrol injector duration (now that you've swapped the pins over in the vehicle injector plugs), I think you previously mentioned setting + pulsed injectors in the software - If so you'll need to change the setting back to read -negative injector pulses.
