Re: free advice given
Posted: Thu Oct 18, 2012 10:16 am
hi gary firstly i have emailed a direct reply to you .
The symptoms sound that a gas leak is present , either into and most likely through an injector into a cylinder or to open air either way it needs urgent investigation with a gas nose ( gas detector ) if your local to me then this can be done foc as its safety critical.
I am located in north gwent near brynmawr NP13 3JW for routing purposes
it could also just be over rich mixture causing similar symptoms , get it checked anyway urgently
regards John
regards John
