IT'S ALIVE.
I answered my own question. With the desktop computer running windows 2000 perched in the driveway and the moniter under the drivers front door ,the system started and autocalibrated quickly through the serial port at 3000 rpm after Tinley Tech talked me through the set up page, thanks guys. I took it for a short drive and all is very well fingers crossed. It runs the same apart from the injector clatter at tickover of course.
Problems; Tried to do the auto cal with my multivalve manually isolated first time
. Second time when it switched to gas a nasty haze of lpg vapour shot from the engine bay so I had to hastily tighten a joint. Those olives are not like water systems where you only have to nip it, all needed a good tug on the spanner to seal completely especiallt the filler stepped olive. Still have to get a filler vapour boot and a LPGA certificate.
When I tried to get some more LPG the pump kept shutting on and off. Is this what they mean when they say multivalves take longer to fill? I gave up at half full.
Total spend so far, just over £600.
Would I do it again? No, life's too short.
