Re: Alternative to valve lube injection...
Posted: Fri Sep 14, 2012 9:08 pm
Thanks again for the info
UK LPG fuelled vehicles and alternative fuel forum. LPG Conversions, Refuel Stations, trouble shooting and more.
http://lpgforum.co.uk/
ok you know a little bit... but completely missing the fact that the throttle body regulates the speed of the air flow and therefore the rev's along with the amount of fuel injected.Taught2BeCautious wrote:I think you have got the gist of the term 'throttle body' but if you think of the air intake system as a simple tube between the engine and the inlet pipe behind the radiator grill - when the engine turns, the pistons suck air in from the outside of the car. If you were to hold a lit cigarette near the intake, smoke would be drawn in from quite some distance - that's because the air just inside the intake is at a much lower pressure than atmospheric, as it is throughout the whole length of the tube.
Whilst the air is moving through the tube, through the filter, the MAF, throttle body and manifold, there will be a vacuum of varying strength (depending on the diameter of the tube at a given point), but enough to draw the lightweight FlashLube fluid up a tube and into the airflow.
At no time when the engine is running, is there any atmospheric pressure within the entire length of air intake system!
It is important not to get the fluid onto the thin-film MAF's because this will destroy them - but it won't do any harm to get some on the throttle valve - the fluid isn't going to stick to anything and cause it to jam!
All but a few molecules will get sucked straight past it at 300mph, not even touching the sides!
As soon as the engine stops, the pressure inside the whole of the air intake system returns to atmospheric pressure, and any FlashLube fluid near the air intake will run back into the bottle - which again, is why you drill underneath the air intake (i.e. upwards) and position the bottle lower down.
You are quite right - I hadn't considered that! Those drips from a 300ml bottle could easily build-up on the 'whacking great plate' thingumy and completely jam a 4.5 litre V8 engine.sijones wrote: You also want the valve lube to be atomised in the air flow, having it hit anything will cause it to turn in to drips and therefore too much of a build up could cause a "diesel" effect where there is too much liquid for the piston to compress and therefore the engine stops dead - not very likely but in a rare case could.
Have you measured this? Not much lower, just a teensy tiny millibar. Flashlube type kits are designed to work with hundreds of millibars, as found downstream of the throttle.Taught2BeCautious wrote:because the air just inside the intake is at a much lower pressure
I would say it's time for a new airfilter there, though we musn't discount venturi effect helping it alongTaught2BeCautious wrote:but enough to draw the lightweight FlashLube fluid up a tube and into the airflow.
But first they'd have to get picked by the slower-moving air in the big air intake.Taught2BeCautious wrote:All but a few molecules will get sucked straight past it at 300mph, not even touching the sides!
For what it's worth, I do the exact opposite. Being quirky I go downstream of the throttle, as close as practical without fouling the butterfly. Then go in from the top (if there is one), imagining that gravity will help the drops to fall through the airflow and encourage atomisation, where it's turbulent behind the butterfly.Taught2BeCautious wrote:why you drill underneath the air intake (i.e. upwards)
What do you mean by this? As even the Electronic kits ive seen still rely on engine vacuum, they just are 'dripped' by an electronic timing setting, rather than a mecanical dial.rossko wrote: But in the end yes, I would agree the simple systems aren't the best choice for this engine layout.
I can't comment on how e.g. the JLM one works, but am familiar with the Flashlube version. What looks like an injector is really a single-stroke pump, it really does pump the lube and so works well with turbos (which doesn't interest you). The pump drive is derived from fuel injection drive, so is properly proportional to fuelling/load. And as a bonus only delivers when actually running LPG.gerlewis wrote:even the Electronic kits ive seen still rely on engine vacuum, they just are 'dripped' by an electronic timing setting, rather than a mecanical dial.
Dat's what the pump is for, it delivers by volume regardless of viscosity.Taught2BeCautious wrote:Whichever system you use, you will of course have to make adjustments to compensate for the viscosity of the fluid in summer and winter, and I don't think any of the electronic kits do that.
The Flashlube should ALWAYS be fitted with its OWN dedicated nozzle and NEVER T'd into any existing vaccum line. T'ing into the MAP sensor line is a geat way to kill a MAP sensor as teh diaphram acts like a pump and ends up filling the sensors with oil!Taught2BeCautious wrote:If the Vacuum line to the LPG system's MAP sensor has been fitted correctly, it will be in the right place to feed the FlashLube into - there's nothing wrong with teeing into it - and no point drilling another hole next to it either!
