Re: Autogas Solutions Corby / Hitchin (now called LPG Power
Posted: Sun Apr 08, 2012 11:56 am
Greetings!
I read your comments with interest re Autogas Experts/Solutions in Corby and Hitchin. I had a 2003 BMW 325i with 41,000 miles converted by them last November.
I do all my own servicing but am no expert on LPG - their installation appears neat and tidy but is not without issues – they certainly are not one of those instal in a day merchants – they took ages to do it!. Believe it or not I went round several installer before choosing them.
At the 1000 miles check up I asked them to check the idle – it hunts up and down quite often (especially when first switching to gas) and so its easy to stall the car.
They checked the gas system and said all was ok and that it was prob related to the car’s existing vacuum system or HT having a minor fault which gas finds but is ok with petrol.
eg they were washing their hands of it.
I was annoyed at this answer as it doesn’t help me get the car running properly – normal garages wont touch a problem like this especially with a new gas instal so I decided to investigate myself.
The vacuum system certainly is an issue just reading BMW forums (and I have had the odd Lambda control tolerance fault codes)so I decided to check the whole system replacing most of the air/vacuum hoses as I went and oil separator (which is a problem on these cars). I don’t know anyone with a smoke tester and if I did the cost of having it done I might as well replace all the hoses. I wasn’t keen on trying the starter spray technique of finding faults as you cant reach most of the hoses anyway. So far I replaced air hoses between Maff and inlet and its already made a small difference so I feel this is the right route.
However if it doesn’t solve the problem anyone know of an LPG expert in Kent – I live roughly between Tunbridge Wells and Ashford?
We have done about 8000 miles since and overall I am reasonably happy with the conversion – of course its not as economical as everyone claims (I was expecting that) but I am running a 325i for the price of 320d fuel and a 325i is about 10,000 times nicer to drive than any diesel!
If my car gets fully sorted I would be interested in converting another car but not before smoke testing the vacuum system! Anyone have a smoke tester in Kent?!
Robin
Robin
