UPDATE :
Since it was going to rain tomorrow morning (apparently), i decided to get the car there this evening in the dry.
I had a bit of a thrash spending ages in the cave with the exhaust extraction on trying to get it to run evenly , even went and got 12 new plugs yesterday at 4.45 and popped them in , that made a good difference , but a constant problem is the mixture leaning off a lot the hotter the car gets , i think i may have to put thermostats in the water cooling system, so it gets to temp and is more stable .
I backed the timing off to 10 btdc , and tickover to 1000 rpm ,then did little jobs , on the brakes test they were better, but i am still not happy with the handbrake, i think that basically needs a re design, with a leverage mechanism..but hey , lets see what happens .
So off i went out of the garden and actually onto the public highway for the first time ....
.this was very exciting ....
but at the first junction the poxy thing tried to stall ,more work needed on the setup ,may need smaller venturis in the lpg mixers..
a ting ting tinging from the rear right showed me the tyre was doinking on the guard ... i carried on .
next junction was a smoooth run round to the left ,and i poobled down the straight 1/2 mile , er ,well no, i didn't ,because at this point the car started not wanting to rev ,and i ground to a halt ...
Its now 4.45 ,and i am supposed to be inserting it onto the garage ramp at 5 ...
I decide its run out of the fuel i put in there ,already , and so call veronica to come and either tow me home , or, if she is up for it , tow me 6 miles to witney for fuel ,bear in mind she has never towed before , yet alone on the wrong side of the car and rd ,and in a turbo charged 1.4 lpg astra ..
Meanwhile ,another car pulls up , and a chap and girl jump out ,and offer , if you can believe this , to tow me to Witney !!!
Then v arrives ,and is super relieved she does not have to tow me anywhere ,and we hook up the worlds shortest luggage straps , and off we go , at 30 mph for 6 miles in the 5pm rush hour, the long queue behind up testified to that.
We have a roundabout and some lights to cope with, but the chap is great and drives brilliantly so all was well , i bang in 30 litres of lpg ,and start her up , and off i roar .
Driving Observations .....
whahhhooobbbly rear end , those tyres may just need a lot more than 25 psi in them.
cooling ran at 9 psi on the rad pressure and 78c on the dig readouts ,until i got to a slow queue and it went to 10 psi with the fans on .
gear lever has too much play due to the transit box having a plastic bush holder in the gearlever neck,and its worn.
engines much too lean still , accel ok ish,cruise spitting every now and then .60 mph cruise fine ....2k rpm in 5th .
steeering light ,and no tramlining.
brakes work , not great but all four brakes got warm.
oil pressure , on the 4.0 all well holds 80 all the time , maybe a sticky relief valve . on the 3.6 ,the oil pressure started swinging up and down .it may just be low on oil because i have the engines vertical and am using the stock dip stick , so i will throw some more oil in there first .
roared into the station ,(oh yes, it has definitely got louder) heel and toeing like a nutter cos it would not tickover , and popped it on the ramp..
the saga continues tomorrow at 8 ....
