Page 6 of 8
Problems
Posted: Thu Feb 09, 2006 10:00 am
by sm200sx
for referance, this is the wideband lambda setup I use for checking the LPG fuelling (and petrol fuelling on other modded 200SX's) <BR> <BR><a href="http://www.innovatetechnology.co.uk/pro ... =2&cPath=1" target=_top>http://www.innovatetechnology.co.uk/pro ... cPath=1</a> <BR> <BR>This WB02 is £400+vat, a professional tuning piece of equipment, and better than what I have seen used at any of the 2 LPGA registered installers that have worked on my car. <BR> <BR>As yet I havent got the cables to tune my own OMVL, but I will, eventually.
Problems
Posted: Thu Feb 09, 2006 1:18 pm
by MarkJones
I don't know the impeadence of a lambda probe and would be concerned about placing that much load on it <BR>You are putting a 10k load on it, with this meter, if the lambda's impeadence is much higher that 1k it will affect the output too much <BR> <BR>The lambda (90%) signal's AVERAGE is ~.5V <BR>but it should not just sit there (unless you take the cat off? <BR> <BR>First of I dont know if IT, is so or not....I've only the wisdom of my electronics friend to go on..and another guy said the lamda makes its own power !!! <BR> <BR>My above idea is ment to come from a seperate lamda that you instal into the exhaust. <BR> <BR>all the best.mark
Problems
Posted: Thu Feb 09, 2006 1:23 pm
by MarkJones
what's wrong with the HTML here <BR>and why am i not allowed to edit my post .. <BR>and most infuriating i have to log-in every time I post <BR>all the best.mark
Problems
Posted: Thu Feb 09, 2006 7:34 pm
by volvo940
Just played with my car <BR>Set the mix rich, lambda steady at .8V put 10k load on it, .8v is now reading .5V <BR> <BR>Your mate is right in that the lamda creates the voltage, but to understand the point connect 9 AAA batterys in series (13.5V) and connect a headlight bulb to it. <BR> <BR>The long term effects of drawing power as opposed to measuring the voltage would certainly lead to damaging the lambda very fast IMHO. <BR> <BR>PS: I think you have just demonstrated the reason why people have reservations on suppling leads etc
Problems
Posted: Thu Feb 09, 2006 7:58 pm
by MarkJones
<b>PS: I think you have just demonstrated the reason why people have reservations on suppling leads etc</b> <BR> <BR>Like I said not tried the idea out ..was going to post more in some forums to discus it before I went on the course of possibly buggering things up. <BR> <BR>So this is what I'm doing discussing. <BR>and not putting any of my ideas into "go" mode. <BR>seams already I've lost your vote of confidence .just by discussing an idea.me thinks. <BR> <BR> <BR>Ok .............so you say it isn't possible ...I'm OK on that..fair enough. <BR>I'm not going to beat you down or insist anything. <BR> <BR>I would never tamper with my gas by way of a computer .until I knew exactly what I was doing .......as you can see by my nature .I ask lots of questions .and keep on asking........... <BR>when and if, I get my leads .I will not do any adjustments until I'm 100 percent confident and certain ..that what I'm doing is the right way to do it. <BR> <BR>There is no way I'm going to burn pistons out etc.experimenting..that's for the guys who have more cash than sense ..not me. <BR> <BR>I'm not a turbo charged race freak . I just want a smooth running engine that is economical to run.. <BR>and that's it . <BR> <BR>all the best.mark
Problems
Posted: Thu Feb 09, 2006 9:46 pm
by richy_boy
I prefer the term "performance car enthusiast" :D <BR> <BR>Rich
Problems
Posted: Fri Feb 10, 2006 9:48 am
by claicerrig
Same here <BR> <BR>Performance Car Enthusiast thats Me..........
Problems
Posted: Fri Feb 10, 2006 8:47 pm
by MarkJones
well..I must say sorry peter linden its been a long time since.. <BR>the calculations for the 18k resistors were done ..for that meter shown <BR>here.. <BR>scroll down to the bottom <BR><a href="http://www.rapidelectronics.co.uk/image ... -0300e.pdf" target=_top>http://www.rapidelectronics.co.uk/image ... 00e.pdf</a> <BR> <BR>..that does not read 0-1 it reads 0-50 <BR> <BR>now can you please have a look again .and say yes or no to it.. <IMG SRC="http://www.my90.co.uk/lpgforum/clipart/happy.gif" ALT=":-)" BORDER=0> <BR> <BR> Sorry it's late..I've just remembered this info. <BR>and don't know if you did your calcs with this in mind. <BR>The resistors are to calibrate rapid's meter TO the lamda <BR>all the best.mark
Problems
Posted: Fri Feb 10, 2006 9:05 pm
by MarkJones
And you are supposed to ignore meter readings <BR>the meter should point strait up at the right settings for fuel. <BR>my idea was to take the meter apart and paint rich ...good...lean on it or words to that effect or graduated colours ..or whatever <BR> <BR>now then.......will it work <BR>all the best.mark
Problems
Posted: Fri Feb 10, 2006 11:04 pm
by volvo940
Mark Sorry but no <BR> <BR>I based the figures on the 100uA meter <BR>As 18k X 2 = 9k + (meter = 1K2) = ~10K <BR>.5V / 10,000 = .00005Amps or 50uA half way on a 100uA meter <BR> <BR>Using the 50uA meter you would need one 18k resistor <BR>18k + (meter = 1k5) = ~20K <BR>.5V / 20,000 = .000025Amps or 25uA half way on a 50uA meter <BR> <BR>20K load on the lambda would be still too much <BR> <BR> <BR>If you still want to do this you need to add electronics, a simple op-amp buffer will do, <BR>pick the amp with care ie. single supply and inputs that work from 0V
Problems
Posted: Fri Feb 10, 2006 11:34 pm
by MarkJones
Ah well I suppose when my electronics expert mate did his calculations ..he must have been having an "off" day <BR>and I know he doesn't know about lamda probes ...because he doesn't have much to do with cars . <BR>still he made a good job of recalibrating these very old milliamp gauges into volt and amp gauges for my boat. <BR> <BR><a href="http://www.geocities.com/aboard_epsilon ... ewint.html" target=_top>http://www.geocities.com/aboard_epsilon ... nt.html</a> <BR> <BR><a href="http://www.geocities.com/aboard_epsilon/instpanel.html" target=_top>http://www.geocities.com/aboard_epsilon ... el.html</a> <BR> <BR>all the best.mark
Problems
Posted: Fri Feb 10, 2006 11:45 pm
by volvo940
No it would have worked fine with the 100uA meter <BR>if the lambda could supply the power that the meter requires
Problems
Posted: Sat Feb 11, 2006 5:59 pm
by alexf2828
I used one of those cheap digital multimeters to check lambda,and you can see it oscillating between the voltages roughly 300mV-700mV,one interesting thing though is you can see the signal disappear when on overrun (foot off accelerator downhill)so could also be used to make sure fuel shuts off
Problems
Posted: Sun Feb 12, 2006 11:12 am
by richy_boy
"To add to Peters point on lambda probes, they are only a correctional device to basically clean up emmissions.If you were to disconnect it or them, the vehicle would still function as norm , but with increased Co etc." <BR> <BR>Yeah, and a serious thirt for fuel! <IMG SRC="http://www.my90.co.uk/lpgforum/clipart/happy.gif" ALT=":-)" BORDER=0> <BR> <BR>Rich
Problems
Posted: Sun Feb 12, 2006 11:13 am
by richy_boy
"To add to Peters point on lambda probes, they are only a correctional device to basically clean up emmissions.If you were to disconnect it or them, the vehicle would still function as norm , but with increased Co etc." <BR> <BR>Yeah, and a serious thirst for fuel! <IMG SRC="http://www.my90.co.uk/lpgforum/clipart/happy.gif" ALT=":-)" BORDER=0> <BR> <BR>Rich
Problems
Posted: Wed Feb 15, 2006 8:30 pm
by classicswede
Sorry for being a bit picky but I hate the incorrect description it should be bi fuel not duel fuel. Dual fuel would meen you are injecting petrol and gas at the same time!!!
Problems
Posted: Wed May 10, 2006 11:52 am
by alexf2828
I stand corrected by keith,rigged up LED's on all four injectors and it does indeed fire 1&4 then 2&3,u can see this by slowing engine down when idling with the clutch,also schematic for petrol side shows only 2 outputs,1&4 are together and the other output feeds 2&3
