And they wonder why it doesn't run right !!!
andy evans autogas
#1 Post by andy evans autogas »
Due to the current massive work load I haven't been on here for a while .... But this I thought I'd have to share with you all ...
ML 500 fitted with a Stag 300 ECU .. OMVL injectors & 2xBRC regulators
No balance pipe between reg's and get this one bank running gas pipes upto 1.15 meter long !!!!
And they wonder why it doesn't run right :? :? :?
.Image
Facebook Andy Evans Autogas
Re: And they wonder why it doesn't run right !!!
#2 Post by LPGC »
Blloomin Eck! :lol:
Did he set it up to return to petrol at low rpm? :lol: Where I've fitted OMVL's on a Merc V8 I've usually made a bracket to mount both rails on top of the engine with outlets pointing outwards, they sit in the space in the middle of the engine cover then.. Surely not fitted by a pro?
Although having said, I have put right quite a few vehicles converted by pros that have two reducers and no balance pipe. Most of them with Stefanelli systems (not even a vac connection on second reducer), but two that spring to mind were a Jag XJ with Bigas system, twin reducer (also needed AEB124s which it didn't have).... don't know who fitted that one. And a Jeep SRT with 2 x OMVL reducers fitted by a well known Autogas place in Yorkshire somewhere around the East coast.. Apparently, the Jag owner thought it was normal that the Jag would run rough on LPG and had put up with it running like that for many years. The Jeep owner had been back to this Yorkshire Autogas place many times complaining of poor running and engine check light problems but they hadn't sorted the problem despite all the return visits.
I once had a DIY customer mount a reducer to the engine on one of these, told him he'd better mount it properly or I wouldn't set it up or have anything to do with it. He ended up asking me to move it and paid me to do so... Dunno why, he fitted the rest of the system fine including the injectors and was easy enough to move the reducer.
www.Lpgc.co.uk
andy evans autogas
#3 Post by andy evans autogas »
I don't know who did the original conversion but the customer said it was somewhere in Manchester. I really couldn't believe my eyes when I saw the lengt of the pipes.... All done now and running perfect .. Another happy customer.
Here's a pic of one of the ones that I DID convert just to show how they can be done.
.Image
#4 Post by LPGC »
Credit where it is due Andy, I know you do a great job mate!
www.Lpgc.co.uk
