This is now doing my head in!!!!!
Ran around with a multi-meter plugged in to various places.
1. 5v supply to map sensor does not change when the power loss occurs.
2. Ground wire to the map sensor does not change.
3. One sense (not sure if it's the vacuum or gas pressure) rises from about 2.3v to 2.9v when missing
4. The other sense wire drops from around 1.5v to .5v
5. Supply to matrix injectors rises slightly. Probably because there is no load on it.
6. Measuring the injector pulse on DC range, voltage drops from around 13.4v to 0.6v. Not firing?
Connected USB to the laptop and the power loss/misfire continued. Opened the Zavoli software while the thing was missing and it continued until the software downloaded the data from the ECU. It now ran faultlessly????
Reloaded the same firmware (4.80) and the fault continued with the laptop disconnected.
Is the ECU knackered or is there some connection that could cause this issue? I'll take the ECU into work and have a look to see if there is anything obvious.
If it is knackered has anyone got a suitable ecu that will plug straight in. It's an early non OBD AEB 2568.
Had enough for today going for the bottle of wine
Rob
