I understand that Tinj petrol needs to be the same on both fuels, should I be looking at Tinj gas for anything?
How do you decide on what the gas pressure should be set to?
I did an auto calibration, got the Tinj petrol times on idle the same and enabled the 'adaptivity' as I have the Bigas ECU connected to the OBD port. This caused the 'corr. gas' percentage at the bottom to increase up to about 15% and it pulled the Tinj petrol time down when on gas. Is this normal or why would it do that? Is it a useful feature or should I switch it off?
It's working out at just under 11.5p/mile so not all bad
Thank you as always
