New here and hoping to learn more about this LPG system of mine
I have a BMW E46 330ci with a KME system installed (20 months ago) and I've had many issues over the last year which are finally fixed - Car had vacuum, oil & exhaust leaks and a faulty o2 sensor and the LPG needed a new filter and injector.
Now that the leaks are sorted I can see using BMW INPA tool that the LPG is simply all wrong.
When I reset the BMW fuel trim adaptation I have near perfect STFT/LTFT when running petrol but they not so happy when I switch over to LPG. Its reading too rich, eventually adapting the LTFT to compensate and in turn causing issues when switching back to petrol.
I'm guessing that this is due to the LPG being tuned/mapped with the petrol when all these leaks were present and therefore i'm thinking/hoping it just needs a re-map?
I have been looking at the software on KME site and diagnostics leads available through ebay and I think I might just be able to sort this myself.
I'm about 75% sure which PC connector leads I require but would rather be 100% sure before i part with the cash!
Could anyone point me in the right direction, maybe recommend a diagnostics/tuning kit with software?
I'm sure I need the kit with 1x black usb cable and 2x small grey cables (one with small connector and other with large) - would this sound about right?
Also, as i'm a novice, how difficult is KME software to use? Is it possible to ruin the system with a wrong click or are the instructions on the KME site straight forward to follow, my first impression is they look ok?
James
