Could someone point me in the direction for OMVL Dream files for Range Rover 4.6 Thor Bosch Motronic?
The ECU needs a refresh and I can t find were I saved the V8 files.
Many thanks.
Therefore you will need to remap the system. As Dai has pointed out, just running the Autocal should get you running OK on a P38, they're very undemanding in terms of tuning. Also as Dai suggested, check for gas coming out of the reducer vac connection.richmac wrote:Both sets of gas injectors are new.
The symbol will flash because by default the OBD protocol is set to 'auto'. It flashes because it is trying to connect to the OBD but there is no connection. It will continue to flash even after autocal but autocal doesn't use the OBD connection. You can disable the flashing by setting OBD type to none. An OBD connection does not effect autocal!richmac wrote:Hi, I have tried the auto cal but it does seem to rely on the connection to the OBD socket as the OBD socket symbol is flashing and the test will not proceed without it ?? Thanks +Regards
