jump started another car now LPG not working?
jdavis986
#1 Post by jdavis986 »
My mate just tried (unsuccessfully) to jump start his car using my car and after failing I go to give him a lift and 2 minutes in of driving my car the lpg button in my car makes a noise and turns itself off, it's never done this before. so I'm running on petrol, I press the button to turn it back on and the noise goes again and lpg system has shut down. Repeatdly does this so now I can't run at all on lpg but there's a half tank in there apparently. It's an lpgtech system. Any ideas why? Surely its related to the jumpstarting attempt, Im pissed off with him because I think he's mucked up my lpg electronics!
Any ideas would be appreciated.
lukie
Re: jump started another car now LPG not working?
#2 Post by lukie »
you think there is LPG in the tank, try putting some in to be sure, when was the last time it was serviced ? does it run flashlube ?
I have know LPG systems to turn themselves off if flashlube is empty
Speedy999
#3 Post by Speedy999 »
Probably what has happened is that the the earth wire or positive wire for the LPG ecu has broken off from the crimp connector that it was soldered/crimped to (one the battery terminals). Easy enough to do when attaching the big clamps from the jump leads.
Look for broken wires dangling around the battery.
jdavis986
#4 Post by jdavis986 »
I've only had the car a few weeks so I'm not sure if it has flashlube or even what flashlube is ! I heard Flashlube is mainly used on fords and mine is a vauxhall corsa so don't think so. I wonder whether it is just an empty lpg tank, because that would mean the fuel gauge is dodgy because when the lpg is running properly it says got 1 or 2 notches left but when it first starts it says its red, so near empty. I presume it just needs to warm up a bit to get an accurate reading.
I will check the lose connection issue as well. Hopefully its that! Cheapest fix the better!
jdavis986
#5 Post by jdavis986 »
Ok guys. I left it a few days and the problem hasn't resolved itself.
Please please please can you watch the video ive uploaded. I've just started the car in cold weather, the lpg tank often registers as empty (red light) when cold. But ten seconds in my first Green light comes on to tell me I've got a bit left in there. But then that dreaded noise starts and everything switches off... please help!
https://www.youtube.com/watch?v=Zvv7vi8 ... ata_player
#6 Post by rossko »
jdavis986 wrote:Ok guys. I left it a few days and the problem hasn't resolved itself.
I don't think anyone said it would.
You don't seem to have tried putting a splash in the tank, nor looked for any snagged off wires?
It may well have lost its setup as a result of a surge during jump starting; you'd need a special lead, laptop, software, and some knowledge to sort that out. That stuff would also enable you to see what it thinks is wrong if say there's a pulled off wire or somesuch.
Or you could get an LPG fitter to have a look.
mat_fenwick
#7 Post by mat_fenwick »
jdavis986 wrote:I left it a few days and the problem hasn't resolved itself.
My vehicle problems don't mend themselves either, although this method is something I have a lot of practice in :(
As the lights come on for a while, I'm guessing it's not a fully broken wire but it still could be a damaged wire hanging on by a thread, which fails to carry any significant current once under load during switch over. But it's all speculation...not an easy one to diagnose over a forum.
It wouldn't do any harm to grab a copy of the software and the interface kit, then we'd be better placed to help you if you can post up screenshots etc.
john_d
Site Admin
#8 Post by john_d »
it doesn't work like that, if it did it would be great though :wink:
jdavis986 wrote:I've just started the car in cold weather, the lpg tank often registers as empty (red light) when cold. But ten seconds in my first Green light comes on to tell me I've got a bit left in there.
dont trust the guage and put some gas in and see what happens.
Ford Tourneo
Nissan Primastar
jdavis986
#9 Post by jdavis986 »
Yes you're all right. It was a dodgy gauge!! Sorry! I'm glad though because that's definitly the cheapest fix even though a bit embarrassing!
#10 Post by rossko »
Glad it was that simple. It's not unreasonable to expect a simple level gauge to work, after all :) just a shame that they rarely do
