I've had a good search about this problem on here and have a few pointers. I just wanted to ask a couple of questions if I could?
I bought a 740i 4.4 V8 with LPG last summer. It needed a bit of work on the engine so I took it off the road in September to replace the cam chains and guides. It took me until February to finish the work due to the weather and having to do the work on the drive.
The car switched over to LPG quite smoothly last summer with only a brief drop in revs. Now it's very lumpy on changeover unless the engine is properly warm. I have the cables and software for both the Zavoli LPG system and BMW OBDII system. The misfire codes recorded after a lumpy changeover to gas, all point to cyclinders 5,6,7 and 8. I have upped the changeover temperature to 45 degrees C and upped the revs to 1500rpm, this helped a little but is still bad enough when cold to light up the engine management light and record misfires.
Once the car is warm, the changeover is seemless and it runs fine on both petrol anf LPG. I'm not sure if I never saw this issue before due to it being warmer in the summer, or whether this is a result of it being sat for 5 months.
I have read on here about the injectors needing cleaning so plan of giving this a go as well as an inline filter change.
I Have a Zavoli Alesi N system split to run each bank of cylinders, so it has 2 seperate 4 way Matrix injector blocks, each fed through their own inline filter (still with Zavoli stickers on it) to their own vaporiser.
Could anyone give me a few pointers on cleaning the injectors and replacing the filters? My biggest concern is that I'm not sure where to isolate the gas before I start taking hoses off the injector blocks. There is a brass knob in the bit that's by the solenoid on the tank.
What should I clean the injectors with? I have a small ultrasonic cleaner which I could use.
Also, does anyone know where I can get the inline filters for the Zavoli?
Many thanks, Marcus
P.S. here are some photos of various bits to helpo identify the systems.
The filters...
One of the injectors..
The tank end...
The vaporisers...
