Tartarini compatibility
- Installer
Need to know if the sequential Tartarini ECU can be replaced with any of teh other AEB ECU's? Has any one actualy done a swap on a failed ECU?
- Installer
Re: Tartarini compatibility
Nobody? Not keen to possibly destroy and ECU testing!
....dont know
Is the pin config the same ?
- Installer
Looks to be but the switch is not the normal AEB type. I might have to just try it.
Plug it on, switch the ignition on and see if you get a connection. Take it from there I suppose.
If it bursts into flames I think we can safely say they aren't compatible........
At least we would know for future reference
Charlie Renard
Yes, I have done it successfully.
- Installer
Great that is just what i wanted to hear. I'll call the customer in for a new ECU
. He will be please as the 6 cyl galaxy is rubbish on petrol
