Hello, i have a 2001 Chevrolet tahoe, 5.3 litre with a BiGas sequential system. the system are not using lambda input to the BiGas ECU, but planning to do this.
Is there any benfits using Lambdas into the Bigas ECU really?
How do i wire them up? Could i just tee them into the cars existing lambdas, and they will work side by side?
Also having problem with sputtering and stopping when outside temp is -3 celsius, and revving down to intersections, red light stops and so on. Cooling fluid is ok, reducer temp is 81, gas temp is reading 21. Is 21 to low?
