Hi Guys
Can anyone give me some advice? I am trying to connect to my BRC just system with my computer to set it up.
I have a cable similar to this http://www.ebay.co.uk/itm/PROFESSIONAL- ... 4170cec5f1 but with the connector advertised as fitting a JUST.
I have some BRC software, but whatever I do I end up with an error saying "error in serial door configuration" or it simply saying it cannot connect to the ECU.
Any thoughts??
BRC Just - connecting to laptop
Re: BRC Just - connecting to laptop
Some Justs have an external diag connector. Some don't - only an internal one. What are you connecting to?
You will need the correct Just software - something else from BRC won't do, not even if its called Just Heavy (that's a different product)
I've never used a USB lead for these, but you'd have to jigger with COM ports in Windows I'm sure.
I have 2 different ECUs in my posession with 2 different plugs.
The one I am using has a black plastic socket, with ovalled ends. I can't remember if it has 3 or 4 pins in it (I think its 3). The socket is about 30mm x 12mm.
(The other one has a white 3 pin socket with much smaller pins and is about 10mm x 4mm)
My adjusting the COM ports I can get rid of the "error in serial door" message, but I cannot get any further - it just won't connect. (After installing drivers for the lead)
I have tried several different versions/issues of what I believe to be "just" software (called interfacciajust - spelling is probably wrong).
Does anyone have a link to a known working version of the software? The Just software manual I have says a "fly" lead with an adaptor works - but the adaptor plugs in to the board internally within the ECU
