Glued heat shrink
Glued heat shrink
#1 Post by classicswede »
My supplier of wiring materials is no longer running and I can not find anywhere that sells a good range of glued heat shrink. Does anyone know were to get it from as the standard stuff is not good enough for my liking.
Re: Glued heat shrink
#2 Post by Tubbs »
Wurth ? Plenty of places on eBay sell 3.1 glued heat shrink. I use a company called trinity wiring products. They always do a deal on 100 mtr rolls of split conduit. Maybe worth dropping them a mail ?
woody
#3 Post by woody »
Try Beal UK [google is your friend] i dont have thier number at home, cheap as chips .
woody
john_d
Site Admin
#4 Post by john_d »
Ford Tourneo
Nissan Primastar
pjpj
#5 Post by pjpj »
I would usually buy this kind of stuff from CPC, it's free delivery when you spend £40 I think it is. If you don't have an account I can recommend you as a friend and I'll get some cashback. :twisted:
Regards
PJPJ
#6 Post by classicswede »
Thanks for the tips. A change of search term came up with lots more results :D
SimonHobson
#7 Post by SimonHobson »
As an aside, where I've wanted glue sealed but don't have the lined heatshrink to hand ... hot melt glue works quite well, but you have to be careful not to put too big a blob on and prevent the heatshrink fitting.
Land Rover 110 V8 LPG
http://www.diy-lpg.co.uk
tommo2009
#8 Post by tommo2009 »
If you check out beal uk they now have heatshrink which has a solder peice in the middle. Bare the two end poke one in either end so they both reach the solder ring then just use your heatgun to shrink the heatshrink and melt the solder. Fantastic little things.
Solder and seal all in one - happy days
#9 Post by Tubbs »
Bloody hell ! Hello stranger :D where you been ?
tommo2009
#10 Post by tommo2009 »
Been in hiding mate lol.
#11 Post by Tubbs »
Youve done a good job ! I had almost forgotten you existed :lol:
gazza345
#12 Post by gazza345 »
Heres another good supplier of all things wiring related:
http://www.vehicle-wiring-products.eu/V ... mepage.php
