Hence my question = What type of gear do the pro's use to tune open loop systems ?
Wide band and AFR perhaps ?
Yes, it was that reason the I considered a wide band sensor and AFR gauge, so I could monitor it under real road conditions, until I saw the price of the kit! (bearing in mind I don't need any of this, I am just learning / playingZebedee wrote:Vacuum operated second choke on the pierburg hasn't helped either.
