how much mpg?
how much mpg?
Hi folks, a little curious on how many miles I should be getting out of my 72ltr tank? I have a range rover 4.6 1998 model. Cheers in advance.
Re: how much mpg?
Single or multipoint injection system. If its an injection system then which type ?
Re: how much mpg?
Small tank for a big car ; I'd guess you get about 57 litres in there? Around 150 miles depending, I would guess.
Re: how much mpg?
I get 180-200 miles out of 66 litres on a 1998 4.0 litre Range Rover on a singlepoint system. Best I've ever managed was 210 miles but that was driving like a granny. If you've got a multipoint I'd expect it to do a bit more but as it's a 4.6 rather than a 4.0 litre I'd expect it to do a bit less. So probably about the same really......
Re: how much mpg?
single point, on a run to Plymouth iv had 200 miles but at the moment im getting around 120 ish. and I put in around 51ltrs.
Re: how much mpg?
10 mpg ?
Re: how much mpg?
I can manage that, but only around town with the Sport button pressed and a very heavy right foot. It does seem a bit thirsty mind.
Re: how much mpg?
to be honest not that heavy footed. alot of traffic around recently due to the snow. and my sport button only works on petrol lol
Re: how much mpg?
Oooh, you don't want to do that, it costs too much! My sport button only gets used on gas when I'm not too worried about how much fuel I use. However, if you are saying that you don't use the sport button on gas because it doesn't go like it should, then it isn't set up right and might explain why you're using as much as you are.ade-5 wrote:and my sport button only works on petrol lol
and looking at your previous thread, it sounds like you may have a leak too. Leaking diaphragm in a life expired vaporiser maybe?
Re: how much mpg?
yeah the sport light doesn't even light up on gas. but on petrol fine. I could probably do with it all being checked out professionally but looking at the pipes ect they look brand new and the chap did say it was serviced a few months beforehand? ???
Re: how much mpg?
That doesn't make any sense unless someone has deliberately done something dodgy so switching to gas disables it, it's only a simple on/off switch that is connected into the wiring to the gearbox ECU.ade-5 wrote:yeah the sport light doesn't even light up on gas. but on petrol fine.
If someone considered that the pipes were looking shabby enough to warrant them being replaced, I would definitely suspect the vaporiser has been there for quite some time and is showing it's age. Check the date on your tank to give you an idea of when the car was converted and if it was done more than 5 years ago then the vaporiser may well be shot.
demonicwillow
Re: how much mpg?
My economy has been quite poor, but sussed it all now so averaging 180 miles around town n lanes from 60L ... 4.0L Jeep
Re: how much mpg?
what turned out to be the problem?demonicwillow wrote:My economy has been quite poor, but sussed it all now so averaging 180 miles around town n lanes from 60L ... 4.0L Jeep
demonicwillow
Re: how much mpg?
DW's problem was one that was more vehicle specific and not just a general problem, yours is likely to be aged components. Considering you can buy a new OMVL R90E for under £100 including postage (http://www.gasit.co.uk/index.php?act=vi ... roductId=6), it's not worth messing around with older kit.
Re: how much mpg?
Quick question on mpg iv just put a new king odb system on my 4.0 2001 grand cherokee and got 150 miles to 43 litres £33 pounds is that about right?
Re: how much mpg?
15 to the gallon ? Not massively good. How are the fuel trims ?
- Installer
Re: how much mpg?
Have I mised some updates on your thread? There is something you should have been asking about the setting up and I have not seen this improtant question pop up yet. Is it running and driving spot on with no quirks?ln69bt wrote:Quick question on mpg iv just put a new king odb system on my 4.0 2001 grand cherokee and got 150 miles to 43 litres £33 pounds is that about right?
