sorry to be a pain in the arse all
right i hould have been clearer on how i have wired my changeover switch so here we go
switched ign live is from the + side of the ignition coil with an inlin 4amp fuse
negative is just to the body but i can put it to the battery negative or the main engine body earth strap (which is closer)
yellow +go' to the petrol cut off solinoid, this is also where i have took my switchd live to power my lectric fuel pump with an inline 4amp fuse
blue hooks up to the solinoids
green is the lpg sender wire which is working
brown is the pulse wire which i had on the negative of the coil but i'll have to check if it switches off after some time, i could still here the swooshing from the vaporiser when the engine stalled,
if the engine stalls & i have a 2nd person with a finger on the solinoids they should feel for instance the vaporiser solinoid click
i'm sure mine does'nt prime when the pulse is on coil negative, it just runs constant!!!
hope i've made sence
just a reminder, i bloody hate electrics lol
cheers again guys, its the old addage so close but yet so far hey!
i can weld, make panels, i can build an engine make it run, i'veven dabbled with upholstry oooooooeerrrmrrrrs! but vehicle electrics just aggrevate me for some reason, i'd love to master vehicle electrics but not sure where you train for that sort of thing if i'm honest
