Has anyone got a set of 6 injectors that they would like to swap for my BRC orange items?
These ones are too big for my car and I could do with a set of smaller ones. BRC Blue, keihin, or whatever injectors would fit my Sequent Plug and Play Fly SF system.
email Tom at motamenda@homecall.co.uk
Wanted: 6cyl Injectors or SWAP for my 6 BRC Orange Max
Re: Wanted: 6cyl Injectors or SWAP for my 6 BRC Orange Max
What is your car? It is unsual to put anything smaller than orange on a 6 cylinder conversion.
Why do you think they are too big?
LPG Cars Ltd
Torrington Avenue
Coventry
CV4 9AP
024 7646 1199
www.lpg-cars.co.uk
Torrington Avenue
Coventry
CV4 9AP
024 7646 1199
www.lpg-cars.co.uk
Someone on here told me that they are too big because my lpg injector times were slightly less than my petrol injection times.lpg-cars wrote:What is your car? It is unsual to put anything smaller than orange on a 6 cylinder conversion.
My car is a 3.0 V6 12v Alfa Romeo 164 with hot cams in it. It uses full bank pulsing, so it pulses twice per revolution instead of once like a sequential system.
Have you set the ECU to semi sequential on the equipment type menu?
If you have and the times are still too short, you can reduce the gas pressure on the vapouriser to increase the opening times.
LPG Cars Ltd
Torrington Avenue
Coventry
CV4 9AP
024 7646 1199
www.lpg-cars.co.uk
Torrington Avenue
Coventry
CV4 9AP
024 7646 1199
www.lpg-cars.co.uk
I did reduce the pressure but it led to lpg cutting back to petrol when I really floored it.lpg-cars wrote:Have you set the ECU to semi sequential on the equipment type menu?
Still Looking for a set if anyone is interested
- Installer
I have a set of used 6 cyl matrix injectors about if that would do for what you want
Thanks for the offer, but I want to replace with Blue type BRC injectors to suit my system instead.classicswede wrote:I have a set of used 6 cyl matrix injectors about if that would do for what you want
