Thats very true, the bigas system is a very good system. Infact one of the longest legged systems i have fitted is bigas. Its been on a mates car for well over 200k so far...7 years and counting. Not a peep of trouble, and its an early gen ecu too.
Not hard to make a kit list though,
Front end kit :- reducer, ecu (should come with switch, looms and pressure sensor), injectors, nozzles for injectors, reducer temp sensor, gas pressure sensor, filter solenoid if not integral to the reducer, vapour filter, 4mm lpg hose, lpg vapour hose 10-12 mm, 16mm coolant hose. 2x water tees and jubilee clips. You will also need some spring clips for the 4mm lpg hose, minimum of 14.
Back end :- centre torroidal tank, multivalve to suit and a level sender. 6mm to poly 8mm (faro elbow) 5x8mm faro straight ends if the solenoid isnt integral to the reducer 3x8mm if it is, recessed bayonet filler. And 10 p clips. Oh and about 8mtrs of 8mm faro pipe.
Thats the lot i think.
