and engines making them go faster ect ect
after a few beer's I got my tools out
2 hours latter in the workshop
then
pistons an rods arrow rods
crank back from frozensolid
Block was also done
all build up with a new gearbox and atb diff fitted
started making it flow more air std
one been made bigger
now speed sorted out lets make it slow down faster
330mm x32mm with 4 pot's
then I found I could fit a 345mm x30mm kit under 17's so this is just as good for fast road use
as my Alcon 6 pot 343mm kit and less then 50% of the cost
rears have also been changed to vented rears at 292mm with custom made plates
a bit of cnc work sorted
new vs old
I do get some help in the workshop but he sleeps a lot
next stage is to fit a LPG kit to the car
started by painting the filler cap
and a shopping list like a boy racer has
I will do a update when i get the rest of the lpg stuff fitted
