hi gary firstly i have emailed a direct reply to you .
The symptoms sound that a gas leak is present , either into and most likely through an injector into a cylinder or to open air either way it needs urgent investigation with a gas nose ( gas detector ) if your local to me then this can be done foc as its safety critical.
I am located in north gwent near brynmawr NP13 3JW for routing purposes
it could also just be over rich mixture causing similar symptoms , get it checked anyway urgently
regards John
free advice given
autogas engineering
- Junior Member
autogas engineering
- Junior Member
Re: free advice given
IMPORTANT SAFETY ADVICE TO ALL WHO READ
IF YOU CAN SMELL GAS OTHER THAN IMMEADIATLY AFTER FILLING THE TANK THERE'S A PROBLEM WHICH NEEDS TO BE LOOKED AT BY SOMEONE WITH THE RIGHT EQUIPMENT ( ALL GAS ENGINEERERS USE SNIFFERS MAINS GAS AS WELL WINK WINK ) .
I WILL DO A SNIFF TEST FOC FOR ANYONE WHO WISHES IT DONE .
