joshnosh wrote:im trying to do this 100% as best as i can possibly do it so if theres anything thats going to make a difrence to performance even a little bit i want to know about it lol
If you get the basics right from the start, any performance issues will be a lot easier to track down later. Safety is more important at this stage, followed closely by checking and double checking the installation procedure.
Make sure the nozzles are the correct size for your engine - and if they are going to be hard to get at when the manifold is bolted back in place, use Loctite Sealer on the threads (I use Loctite 577), clip the hoses securely, and number the other ends of the hoses if you can't see which one is which afterwards.
joshnosh wrote:is it important to drill all the holes the same leanth up the tract?
i can't see that being a problem from the pictures, you should be able to find a height that suits all of the nozzles, within a few mm - but make sure you allow enough space for the hoses, when they are fitted, so that they aren't kinked, near to something too hot, or rubbing on anything. Angle them downwards if necessary.
They don't all need to be on the same side of the petrol injectors either - just check how much room you have to play with when the hoses are in place for each cylinder, and base your judgement on that.
