Town gas cng ?
Hi every one
Advice before I go any further
I need to run a generator it will use a petrol engine
About 100 horse power was going to us one with a carb
So that I could use a open loop system
The question is it all the same front end if I use cng
And can I run it strait of the gas main ?
As I have a gas supply near buy
Town gas cng ?
Re: Town gas cng ?
Don't think anyone has made Town Gas for decades.
I guess in theory you could use an ordinary autogas regulator for that, not sure, but power output would be limited by the size of the inlet.
I doubt you could get 100bhp out of an ordinary domestic gas pipe, if that's what you mean by 'gas main'.
There's probably regulations about how to go about it.
Same mixer, very different regulator for CNG.grumpydad wrote:The question is it all the same front end if I use cng
That's not CNG and you should not confuse the terms.grumpydad wrote:And can I run it strait of the gas main ?
markocosic
Re: Town gas cng ?
Pressure is low - nominally 21 mbar (0.021 bar) - and the capacity depends on the meter installed.
A "typical" meter fed from a "typical" low pressure supply is limited to ~64 kW. That's heat output, not engine output. Assume 20-25% efficiency for your generator so that supply might run a 12-15 kW generator.
Some properties are fed by a "medium pressure" supply to the meter. This is about 2 bar and you can nail a jock-off great big regulator onto this supply if you want to. When you get the quote for fitting one from National Grid - and the regulations with teeth for appliances connected directly to mains gas - I suspect that a bulk LPG tank or running a mains electrical supply will look far more attractive.
Not that I've ever sat down and looked into how long it'd take to fill a CNG car from the grid you...
