Still plugging away at getting my LPG kit calibrated properly, it's running well enough if a little under-powered.
The voltran auto-calibration utility seems pretty good as long as you drive it enough to fill all the fields in.
The question I had was whether or not I should be resetting the long fuel trims prior to calibration.
The trip comupter thinks I should be getting around 20mpg, but it's between 16 and 17. Appreciate that the trip computer won't be correct on LPG, it'd be nice to get a little closer to what it's reading though!
Any input appreciated, cheers!
