hello to you all
indy scooby
hello to you all
#1 Post by indy scooby »
Hello im looking into a conversion on my 2002 impreza turbo and was looking at fitting a kit myself in a word is this something that you would recomend im a maintainence engineer and am very methodical.If so what kits would you recomend my car has been remaped and decated not sure if this may make a differance?
If not can you recomend someone around the bedfordshire area as there seem to be lots about these days..also i have been advised to fit a valve lube kit any ideas how much per mile this adds to the cost?
Many thanks phil.
Re: hello to you all
#2 Post by Tubbs »
Proper P.I.T.A if im honest, but ok once done, you need to remove the manifold to get the injector spuds in. Some of them dont adhere to the k line protocol and you plug your obd reader and it comes up in japaneese !
Also current not voltage based lambda sensors. Not a good idea for a first conversion. The flashlube usage is minimal. But you are right, they definately need one. Electronic multipoint variety ideally.
If you work out a litre every 5-7k and a litre is a tenner ? Its not really going to stack up in the calculation.
indy scooby
#3 Post by indy scooby »
OK thanks for that is there somewhere that you can recommend to get the kit from?
#4 Post by Tubbs »
Tinley tech is a good bet....
tommo2009
#5 Post by tommo2009 »
standard flashlube may not work as the manifold pressure goes positive on a turbo car. lambda's don't need to be connected, they don't do anything, they only monitor. done quite a few scooby turbo's, and they all run just fine. They do however have a habit of eating plugs and coil packs, even on petrol
tommo2009
#6 Post by tommo2009 »
OBD connection is also optional, if it is set up correctly it shouldn't reqiure it. it is handy but not essential.
indy scooby
#7 Post by indy scooby »
Many thanks guys..
