I have a suspicion that the pipes from the injector blocks to the inlet manifold on my Zavoli system may be incorrect .. the motor has just been in for an exhaust replacement and I am getting intermittent misfire and O2 sensor codes.
I have a vaque recall of being told (but never looked ) that from eachset of injectors 2 pipes shoul stay on the same side as the block and two should cross the valley to the other ..
is this so, and if so just exactly how should they be routed .. currently all pipes cross the valley to the other block. I've photo of the general under bonnet layout in case it helps
