errm but it isn't it doing the same on both fuels? I can't see any reason to assume its an LPG install issue, though it might be of course.andy evans autogas wrote:just been trawling u tube and found a badly converted L322 running 13% out on slow trims
C4 grand picasso
Re: C4 grand picasso
andy evans autogas
- Installer
your right rossko but after a closer look when on gas it hardly goes- and when on petrol it hardly goes+ so i reckon 5 more mins till it light's uprossko wrote:errm but it isn't it doing the same on both fuels? I can't see any reason to assume its an LPG install issue, though it might be of course.andy evans autogas wrote:just been trawling u tube and found a badly converted L322 running 13% out on slow trims
Facebook Andy Evans Autogas
andy evans autogas
- Installer
nice to see you today si and glad you got it running ok now
Let's turn that around and me say a big thank you to you for pointing out my mistake!andy evans autogas wrote:nice to see you today si and glad you got it running ok now![]()
After changing the order of the injectors - must say thank you to citroen for changing the firing order! (that you found) pushing the vap pressure up and a re-cal it's as smooth as a baby's bum!
I'll drop the poly adapters back that I had off you as soon as I can...
And then we'll sort the cert out
andy evans autogas
- Installer
Oh forgot to mention got the previa sorted.....I didn't alow for the thickness of the mechanic.......remember ..red -to -red....black - to - black....and ....blew to bitts....
oh dear...!
