Toyota Supra
Toyota Supra
#1 Post by Tubbs »
So i have started a new thread. Just so you can all catch up (if you are interested remotely) i did an alfa for a chap a few weeks ago. A few members wanted pics, so i said i would oblige as i was doing a mk4 toyota supra this last week. Its a straight 6 normally aspirated, using the EMER system that im always banging on about.
So just to get you up to speed....
I was confronted by this
Which after a lot of head scratching and fabrication eventually turned into this
The finished product doesnt look too bad, now if you are using a flexible gas tight box, this is what i chose because they are smaller and i was worried about obscuring the view from the back window. But EMER make extendable vent hose which when working with a 'condom' makes the job far easier.
Re: Toyota Supra
#2 Post by Tubbs »
So the veiw from inside is great, it doesn't obscure anything really from the drivers seat.
So we move on, front to rear was a breeze, dropped straight out and along side of the brake lines straight up into the engine bay.
And what an engine bay !
after a bit of head scratching i got started, working out where everything was going to go, plumbed in the reducer coolant hoses, gas line and vapour filter.
Re: Toyota Supra
#3 Post by Tubbs »
So bit of mad woman's knitting !
Its a game of wheres wally, see what you can spot that i had to move ?
Hope ive uploaded these in the correct order !
Re: Toyota Supra
#4 Post by Tubbs »
It would have fitted there, until i noticed hidden away was the L/P connector for the aircon, been a bit of a bugger had the chap popped into kwik fit for a cheap old air con regas !
So i think we are ready for the finished photos. Notice the injector rails standing up nicely, nice and warm, nessled in the heart of the engine.
Still set the change over temp to 40 degrees though. When it hits it the gas rail temp is already at 25.
And from the side
Oh and does it go, hell yeh ! Absolutely full of beans, it was slightly boggy between 2500 and 3k initially on the autocal map but then clean as a whistle. Too much gas, so i leaned the system off. At the max the the injector timings touch 17ms. No pressure drop at all really, holds just below a steady 1.4 bar.
2.6mm nozzles.
Ok im bracing myself !!
carl0s
Re: Toyota Supra
#5 Post by carl0s »
Looks great! Is the flashlube needed on these engines then?
I don't know if this guy is missing it, but there's a recoiled boot curtain/blind thingy that would probably stretch over that tank quite happily.
Carl
Re: Toyota Supra
#6 Post by Tubbs »
No, he isn't missing it. Dont think it's going to fit though. The locating lugs are lower than the tank.
But he did say he would have a go at adapting it. It's all good though. Nice chap. Hope he has many (cheaper) miles out of it. I have to say I wasnt too taken with it at first, loud as hell, harsh acceleration, but it grew on me over the week. My unit is a big grain barn. I tell you when you start it in there you can hear it for miles !
I was quite sad to see it go in the end.
mat_fenwick
Re: Toyota Supra
#7 Post by mat_fenwick »
Tubbs wrote:My unit is a big grain barn.
Do you rent out space in it? I.e. a vehicle sized space... :wink:
Re: Toyota Supra
#8 Post by Tubbs »
How far away from me are you mat ?
J66P
Re: Toyota Supra
#9 Post by J66P »
looks tight in there but I have to say you should have seen under the bonnet on my Twin Turbo version I had a few years ago :shock:
Toyota Colorado 3.4 V6 (Prins LPG)
VW Caravelle 2.8 V6 Surf Bus (Prins LPG)
VW Passat Est 140 2ltr Blue Motion (work car)
Re: Toyota Supra
#10 Post by Tubbs »
Oh i have, and one of those 300 zx nissan thingy's. Mind you its pretty tight under the bonnet of an s4 too.
tommo2009
Re: Toyota Supra
#11 Post by tommo2009 »
picture of a 3000GTO twing turbo i did a while back. this was tight
tommo2009
Re: Toyota Supra
#12 Post by tommo2009 »
this was the tank on it
john_d
Site Admin
Re: Toyota Supra
#13 Post by john_d »
jesus that tank looks massive! how big is it?
Ford Tourneo
Nissan Primastar
tommo2009
Re: Toyota Supra
#14 Post by tommo2009 »
think it was around 80litres, it was a while ago, and I have slept since then :lol:
