lpg gauge on dash
bishbosh26
lpg gauge on dash
#1 Post by bishbosh26 »
Hi Everybody
Nice forum with lots of imformation ))))
A question for i have is my car has a 60 ltr tank i run till it is showing red which is about 168 miles but
i can only get abot 26 liters in has anybody any idears , i have only had an lpg car for a week so this is all new to me.
sijones
Re: lpg gauge on dash
#2 Post by sijones »
Tank gauge are never accurate, fill it, reset the trip and drive it until it runs out, that will give you a rough idea of how far you can get. Then when you fill it back up, make sure you fill it to roughly 80% of the tank size.
All of us basically do the same, reset the trip and go by mileage...
EDIT - If you don't get roughly 80% fill capacity then we go down the faulty route....
bishbosh26
#3 Post by bishbosh26 »
ok thanks i will try that should be empty mid week so will run till it switches over. I have called the person i got the car from
and it was installed 3 years ago and not had a service. On lpg systems uther than testing for leaks and changing filters is there anything else they do on a service?
sijones
#4 Post by sijones »
There's another thread that's going at the moment on what's in a service.... maybe follow that.
#5 Post by Gilbertd »
My P38 Range Rover does roughly 200 miles to the tankfull, but the red LED comes on after around 100 miles. So it tells me it's empty when I have half a tankfull. Some can be made a bit more accurate than that but not by much.
bishbosh26
#6 Post by bishbosh26 »
thanks will try run it dry ))))
