Hi Everybody
Nice forum with lots of imformation ))))
A question for i have is my car has a 60 ltr tank i run till it is showing red which is about 168 miles but
i can only get abot 26 liters in has anybody any idears , i have only had an lpg car for a week so this is all new to me.
lpg gauge on dash
Re: lpg gauge on dash
Tank gauge are never accurate, fill it, reset the trip and drive it until it runs out, that will give you a rough idea of how far you can get. Then when you fill it back up, make sure you fill it to roughly 80% of the tank size.
All of us basically do the same, reset the trip and go by mileage...
EDIT - If you don't get roughly 80% fill capacity then we go down the faulty route....
bishbosh26
- New member
ok thanks i will try that should be empty mid week so will run till it switches over. I have called the person i got the car from
and it was installed 3 years ago and not had a service. On lpg systems uther than testing for leaks and changing filters is there anything else they do on a service?
There's another thread that's going at the moment on what's in a service.... maybe follow that.
My P38 Range Rover does roughly 200 miles to the tankfull, but the red LED comes on after around 100 miles. So it tells me it's empty when I have half a tankfull. Some can be made a bit more accurate than that but not by much.
bishbosh26
- New member
thanks will try run it dry ))))
