C4 grand picasso
andy evans autogas
- Installer
C4 grand picasso
C4 grand picasso 2008 no room for a tank (air suspension/6 seats small well in floor for inflater kit) making a start in the morning will put some work in progress pics up tomorrow......should be fun......
Facebook Andy Evans Autogas
Re: C4 grand picasso
Head scratching day for you tomorrow then
andy evans autogas
- Installer
well today is the day that 6 become 5 it's ok to leave one oh the kid's at home !!!!!!!!!!!!!!!!!!!!!!!!!!!
you cant make an omelet without loosing some seats afterall !!
andy evans autogas
- Installer
ah well omelet for dinner tonight just got home tank in filler in back broken (me and the job
) just as well it was bought for a taxi and he doesn't want the back 2 seats . best advice i can give to anyone wanting to do one of these is DON'T DO IT
. would have had some photos but i left the camera in work
well you'll just have to go and get it thenandy evans autogas wrote:would have had some photos but i left the camera in work
Ford Tourneo
Nissan Primastar
Ford Tourneo
Nissan Primastar
Where abouts did you put it?andy evans autogas wrote: filler in
andy evans autogas
- Installer
put the filler in the nearside rear just below the petrol filler can get access from under splash guard loadsa room looks ok put the tank on the off side rear longway's custom built frame to fit under rear seats and at the front stepped down to rear floor vent pipes come out just in front of the tank through the 50mm insulation in the rear floor......what a day!!!!!!!!!!!!!sijones wrote:Where abouts did you put it?andy evans autogas wrote: filler in
andy evans autogas
- Installer
john_d wrote:well you'll just have to go and get it thenandy evans autogas wrote:would have had some photos but i left the camera in work
not a chance 11 hours is quite enough
andy evans autogas
- Installer
right cameras home and just loading some pics onto photo bucket then ill put them up...
andy evans autogas
- Installer
ok here goes ....looked underneath faced with this........!!!!!!!!!!!!!
.under the bonnet .
.in the boot.
.more to follow!!!!!!!!!!!!!!
..under the bonnet .
..in the boot.
..more to follow!!!!!!!!!!!!!!
andy evans autogas
- Installer
and after a bit of this.
and this.
we ended up with this.....sorry about the dust on lens....
and the filler......
.and then under the bonnet........
.reg in ......
...ecu in.....
....injectors in.....
........now you see it all.....
.....and a bit more......
.......and now you dont .......
.all done..........
.and this.
.we ended up with this.....sorry about the dust on lens....
.and the filler......
.and then under the bonnet.........reg in ......
...ecu in.....
.all done..........why is it you never see the headline PSYCHIC WINS LOTTERY !!!!!!!!
ECU is upside down.......
andy evans autogas
- Installer
Gilbertd wrote:ECU is upside down.......
.that's so the data doesn't fall out
andy evans autogas
- Installer
Its not upside down the sticker is on the wrong way :
D
........funny you should say that I've never seen a petrol ECU with the plugs on the bottom.......
D
He is right about the ecu thing. It's just a stupidism really. When ever you open an ecu box they are all upside down. I'm the same, I will put them upside down in an ecu box, but if they are under the bonnet I generally get them plug down.
The other thing that peez me off is the ecu must be secured thing. It's a nice snug fit in the box with the ecu's, but you still need to secure it. It's not going anywhere once the lids back on is it ?
It's only a matter of interpretation - "secured" does not say "screwed down" or "welded in". Use a 'purposive' approach - what is the purpose of securing it? So it doesn't fall in the works, or rattle internally to sparky self destruction. Does wedging it in a closed box meet that purpose? I would say so.
andy evans autogas
- Installer
Anyway you can't see it when you close the bonnet
.but then again you can't see it with the bonnet open.nice job tho hey.....
